Hi,
Am I right in saying that a "winterized cottage" is technically one that has been prepared for winter in the sense that no one would be living there...? I often hear of the term "winterized" used in a different sense, where it has been insulated, for example, so that one can live there in the winter as well. Would that be "all season"? Came up again today when a client called for a winterized cottage inspection. I started asking about utilities, water... What they meant was that they live there all year long, so it is a well insulated cottage suitable for winter living. Thanks, Paul-Marc |
I've heard the term used both ways. The important thing, I suppose, is to make sure your client and you both have the same understanding while communicating. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Ditto.
Around here, winterizing means preparing the house for the winter, knowing that the heat will not be on and the house's water piping water heater, radient heat pipes, drains and other components that can be damaged by cold are taken care of. As to a house being able to be lived in, during the winter, that is just referring to it being heated, insulated and all the other normal stuff that any house should already have. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Agreed! Thanks Larry and Will. Paul-Marc |
| Winterized properties | bclark | Plumbing Inspections | 23 | 2/1/08 8:58 AM |
| Season Greetings and thanks NACHI for a Great Year | rfrancis | Miscellaneous Discussion for Inspectors | 15 | 12/23/07 11:43 PM |
| Bush Predicts Hurricane Season | jschwartz1 | Miscellaneous Discussion for Inspectors | 0 | 5/31/07 7:27 PM |
| It is Obviously Election Season - Deadbeat Alert | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 5/3/07 3:54 PM |
