Bill Featherstone is a non-member guest and is in no way affiliated with InterNACHI or its members.
something else?
Which is the best product when placing poreclain tile on an AdvanTech subfloor? What about when using porcelain tile in a tub/shower surround? |
I would not use these products on the floor,I would use Wonderboard in a tub/shower. BTW Any relation to Willy Featherstone? (Boxer) or are you Willy? 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
For floors, use self leveling mortar, with a latex additive.
I like cementboard for walls. Make sure to have a rubber membrane behind it if this is a shower enclosure. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
A clip....
"WonderBoard (1/2") has been rated by the Tile Council of America (TCA) for use as part of a ceramic tile installation system for plywood subfloors with 24" o.c. joists and 23/32" exterior grade plywood." "Similar to the other CBU's, WonderBoard must also be installed into a bed of fresh latex modified mortar, seams staggered, screwed or nailed every 8" o.c. and the seams taped with 2" fiber glass mesh tape and leveled with mortar." I've used most products and haven't had any problems. The key is to listen to installation specs. But if you have a crappy subfloor or foundation system, your going to eventually have cracks in your tiles, regardless what product you use. Also, Wonderboard is recommended for horizontal use only. Last edited by bdoles2; 11/9/07 at 10:34 AM.. |
No relation to Willy, that I'm aware of anyway. |
There is a really good new product by Georgia Pacific "DensShield® Tile Backer" it is great when properly installed I have not seen any cases of water penetration. Actually the whole dense board line I love very versatile. In case your interested here is the link to check out the product http://www.gp.com/build/product.aspx?pid=4684
I have renovated and built many new washrooms and I use 3/4" plywood with a cement based Polymer adhesive. This does the job everytime. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
[quote=Bill Featherstone]What would you use on the floor?
Check out a product called "ditramat" www.schluter.com pricey, but works great |
[quote=bjones1]
Mike Holmes has everybody fooled. You do not need to use expensive products that he endorses on TV Remember who the sponsor of his show is? [Home Depot] 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
[quote=mkyriacou]
So, I should start watching his show less and start reading posts on this board more? |
I don't think anyone here is for the benefit of bursting one's bubble as you said. We are all here to help and Mario has some good points as to the promotion of the product that gives this guy a paycheck. In all honesty, ceramic tile should not be installed on: Luan Flake Board Particle board Hard board Vinyl tile and linoleum Press board OSB and anything less than a subfloor that consist of at least 1&1/4" thickness. OSB layer on typical framing should be supplemented with at least a 5/8" BCX plywood nailed at 6" or screwed on center. A fortified latex thin set material should be used and the reason for the 1&1/4" material is to maintain the 1/360 deflection as reccommended by the tile institute and reccommended practices. The other alternative would be to use the recent cementious board set in thin set material for adhesion and install the tile. Hope this helps. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
[quote=mcyr]
Thanks for the info, Marcel! |
