Old 2/1/12, 6:19 PM
David C. Macy's Avatar
Default Wood burning insert with a turbine vent??
This seems like a bad idea to me, what are your thoughts. First time seeing this.
If it is windy would not the turbine potentially cause some draft problems?
ID:	52107   wood-burning-insert-turbine-vent-202212-125-small-.jpg.JPG
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/1/12, 6:29 PM
James F. McKee's Avatar
Default Re: Wood burning insert with a turbine vent??
Me thinks Your gut is right on this one Dave...there is no fixin stupid...I'd recommend removal of turbine vent and installation of a proper chimney cap....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/1/12, 8:13 PM
Michael J. Parker Michael J. Parker is offline
That's a new one. That's what I like about this business. You see something different every day. At least the rain can't get in. Need to call in a professional to correct it.
Michael J. Parker
The Neighborhood Home Inspector, LLC
Home inspections in Clinton, Essex and Franklin Counties in NY State
http://www.PlattsburghHomeInspector.com
www.TheNeighborhoodHomeInspector.com
Old 2/1/12, 8:27 PM
Joseph Hagarty,  CMI's Avatar
Defective Installation
- I can not imagine any manufacturer of a stove or appliance approving this installation.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 2/1/12, 8:29 PM
Stephen W. Stanczyk's Avatar
So it is something that some have never seen. That doesn't make it wrong. Did anyone take time to look it up? It seems they are sold by most chimney supply stores and installers. The application is for areas with wind related downdraft issues. This product will not create a draft, it will only prevent a downdraft. So you could recommend it be removed, but it may fill their home with smoke.
Stephen Stanczyk
Old 2/1/12, 8:30 PM
I've seen some used but, as I recall, there was a problem with some not spinning due to creosote buildup and that one looks like the rain would run right down the pipe into the stove.
Larry Kage, CMI
231 929 3525
Old 2/1/12, 8:39 PM
Originally Posted by sstanczyk View Post
So it is something that some have never seen. That doesn't make it wrong. Did anyone take time to look it up? .
The fireplace is designed to be wood burning.
And now with a stove insert.
soooo...
The fireplace is not being used as designed and initially intended.
Therefore....
Without a Level II Inspection and certification provided for the current installation and application,
the condition would be deemed Defective....
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/1/12, 8:53 PM
That is nonsensical. Unless you confirm there was no permit pulled (if needed in your jurisdiction), one shouldn't call it defective. If that were the case, you would be calling the whole home defective unless you do permit research on each home you inspect. So which is it? Do you do a permit search on each home or just call them all defective? Oh that's right, I forgot you were around when they invented fire......
Stephen Stanczyk
Old 2/1/12, 9:02 PM
I could not find or see a manufacturers identification plate to research. Plus the lady had a fire going.
I have never came across a turbine vent on a fireplace before.
Seems like there are better alternatives.
Old 2/1/12, 9:08 PM
Bob Elliott's Avatar
I think spinning creosote partially blocking the chimney is always lots of fun.
Old 2/1/12, 9:35 PM
Christopher Currins's Avatar
Doesn't seem like a very good idea to me. Poor drafting when there's no breeze would be one reason, plus getting blocked with soot. Great example for strongly recommending a Level 2.
Turbine Ventilators
for attic ventilation and chimney draft assist
Alternative to down drafting chimney.
Link: Chimney Cap Design Web site
Link: vacu-Stak
Christopher Currins
Certified, Licensed
Old 2/1/12, 9:47 PM
In Pennsylvania (prior to July 2007), building code rarely existed.
Building Trade Contractors (Carpenters, Plumbers, Electricians, etc...) only became licensed 2 years ago.
I do not have to prove that the installation is defective.
The Fireplace has been modified from the initial design use and intent.
The burden is now on the Homeowner to prove compliance with current building code and stove manufacturer's specifications.
Level 2 Inspection and Certification required prior to closing.
Joseph P. Hagarty
Phone: 610-399-3675
Old 2/1/12, 9:48 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
A really bad idea!
Plus: Has the chimney been relined with stainless steel to match the outlet breech of the stove- required here in Canada.
If the chimney is an exterior version, it will be cool/cold and needs a draft assist to burn properly. Relining the chimney will correct the draft problem (if there are no other issues) and the turbine can be removed. It will also be a much safer installation.
Old 2/2/12, 8:38 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
I see this adaptation for increased draft on wood burning chimney's in my area.
The owners explain there is insignificant drafting not understanding that reversed daft my be occurring within the residence.
The chimney is to low, to many turns in the liners, liners to small, and the list goes on to pour circulation in the residence.
They install a turbine seeing it applied to other homes and through street maintenance chat.
It is a safety issue first and foremost in my opinion.
I could be wrong.
The bushings, now made of nylon these days will melt. The vertical rod that holds the turbine will twist along with the collars, one for the turbine and the other for the turbine housing will also warp and touch each other.
Fiction due to the materials heat creates material torsion that will eventually cease the unit. The rotation of the turbine will stop over tine.
The real cause of the daft being ineffective are listed above.
It is a combination of the lack of proper techniques . The fire box comes with manufactures instructions.
They are normally used before reading to start the first fire.
Also pour restoration and repairs case drafting issues.
That handy man thingy we all observe while doing home inspections..
As you know the most dangerous times for toxic fumes is as at fire strat-up and cool-down.
There is insufficient heat to create up draft
The fumes will back-draft if conditions are meet.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 2/5/12, 10:23 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
This will not pass a WETT site inspection in Ontario and will create a dangerous roaring fire during windy conditions. It also could be so strong an influence to effect the proper operation of the gas HWT or furnace along with all mentioned by Robert.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Do we need a W.E.T.T certification to pass the wood burning stove. dmcpherson Canadian Inspectors 3 5/15/09 11:06 PM
Extractd from the archives, Thanks Paul for this list! jtedesco1 Electrical Inspections 4 1/2/07 7:51 PM
Pressure Treated Wood Basements lkage Structural Inspections 4 8/22/06 5:14 PM
Wood Burning Furnace dmacy Inspecting HVAC Systems 6 6/21/06 11:59 AM
