Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm not sure if this is where to post this, but here it is.
I came across these wood cabinets installed 24 inches over an island range top. There isn't a range hood or any type of heat shield installed under the cabinets. I think there may have been a range hood installed there, but it could have been removed during a remodel. What is the rule of thumb for distance between the range top and bottom of a wood cabinet, or is this ever permitted? |
Shold be around 30 depends on the manufacture of the cook top. See page 4. http://products.geappliances.com/App.../r08209v-1.pdf
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Typical mounting heights of cabinets would dictate that the sink base is at 36" and 18" between the upper cabinets and the upper cabinets are 30" in height for a total of 7'. When an exhaust fan is installed, the cabinet above it would be 18" therefore, with no exhaust hood, the cabinet would be 30" above the range top.
I see no problem with this other than the fact that you are not exhausting the steam or food odor out of the house and the humidity levels might increase. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Tech Links Page | bkelly2 | Structural Inspections | 3 | 1/11/07 4:18 PM |
| Extractd from the archives, Thanks Paul for this list! | jtedesco1 | Electrical Inspections | 4 | 1/2/07 7:51 PM |
