Old 4/14/09, 7:20 PM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default Wood stove installaion
Question for anyone that can help answer this. I found fiberglass insulation installed in the flue of the chimney around the 4 in flue pipe for a wood stove. Used to block the draft from putting the metal flue up the chimney. You can see it from looking up the flue from inside the house. This is regular insulation for walls that does not have a paper vapor barrier. I don't normally see this. Most of the time i see a sheet metal cover or foil backed insulation to draftproof the chimney. The stove store that installed it says it is ok because fiberglass insulation is not a fire hazard. Any comments would be appreciated.
Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America)
Old 4/14/09, 10:33 PM
Wayne B. Wilson's Avatar
Default Re: Wood stove installaion
I had a chimney stamped do not allow insulation closer than 2 inches .
Old 4/14/09, 11:08 PM
Brian E. Kelly's Avatar
As the Stove Store Guy to show you the installation manual for the installed flue pipe.
Old 4/15/09, 1:01 AM
Thanks Guys I thought that was right and i will call him tommorow and have him show me the specs.
Old 7/29/09, 2:28 PM
Rick Vollmer Rick Vollmer is offline
Please Note: Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just read this post and was wondering what the final findings were. My insert has been set up this way, wrapped in insulation , for the last 16 years and I have had no problem, but now after reading this I am curious, since I need to replace the insulation due to rain water getting into it.
Thanks in advance...
Old 8/1/09, 6:20 AM
Unmoderated Guest
If any insulation is used at all in contact with a flue, I believe it should be fire-safing insulation, not typical fiberglass insulation. Berst would be a thimble manufactured for the purpose, preferably by the flue manufacturer.
Old 8/1/09, 7:50 AM
David P. Valley's Avatar
http://saveenergy.owenscorning.com/2...te_around.html
Mark,
Why not install some sort of collar at the chimney penetration. This will prevent draft from entering the outer flue cavities.
Structural Links Page mcyr Structural Inspections 52 8/1/09 11:54 PM
Mold Resistant Wood by FrameGuard mcyr General Inspection Discussion 15 1/16/09 10:14 AM
The Rise and Fall of CCA Wood Preservatives mcyr General Inspection Discussion 3 5/4/08 12:19 PM
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 9:30 AM
