Recent inspection:
20 yr old brick two story house (POS) Door to master bedroom on second floor will not stay open. Door frame and jamb are plumb and square, no visible cracking in walls around the door. There is a hallway below, with a closet on the first floor The bedroom door is right above the closet at right angles to the closet opening. There no visible cracks in the closet either. Any ideas as to what is causing the door to swing closed all the time? Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
Do you have pictures. Hinges spring loaded?
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
This may seem silly,
Kevin Kevin M. Kenny, Sr. Kenny Home Inspections Oak Forest, Illinois 60452 Nachi #6070990 http://kennyhomeinspections.com
Oh yea--closet extended into the garage Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 Last edited by dcossar; 1/1/10 at 1:39 PM.. |
The only two thing that I can think of that would make a door close on its own.
1. The wall that the door sits in is out of plumb. 2. The hinge gains in either the door or the jamb are not equal, usually compensating for something. This usually shows up in how the door lines up against the door stops. Are there two hinges on the door or three? Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com |
If a door is swinging open or shut then the door, jamb or walls are out of plumb, that simple............. its called gravity.
If all is as you say, douglas; i could only think it is hinge related. Something is out of whack, and if the frame and walls are all plumb and square; what else could it be? A simple adjustment on the hinge setback should correct the problem.
Harold J. Lowe C.M.I., C.C.I. Eagle-Eye Healthy Home Inspections Sharondale Academy of Home Inspections www.healthyinspections.com harold@cannachi.org haroldjlowe@hotmail.com home-905-576-4337 cell-416-912-0852 CanNachi Director of Education Board Certified Master Inspector Certified Infrared Thermographer Pro-lab Certified Mould Specialist IAC2 Certified Indoor Air-quality Consultant Certified Commercial Inspector Toronto/Durham/Kawarthas Proud InterNachi Member # 06091197 |
I agree with the answers given. Sounds like a deal killer issue.
If there are two hinges on the door, a bow or warp in the door can create this situation. This is very isolated and rare though. Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com |
Simply take a 6 ft level or plumb bob, and drop a line on both the hinges, door and jamb.....that will tell you what the problem is in about 10 seconds.
A warped door will show by the reveal of the door stop... but even then a warped door is not going to cause it to open or shut without one of the other axis lines being out of plumb. Personally a plumb bob is the most reliable method of checking something. I still use them when I am framing homes as well as checking the accuracy of my levels. regards Jeff |
I have read the post above and are all accurate in describing points that cause the door in self-closing.
A couple were left out I believe that could also contribute to this problem. An interior door can be installed in a plumb wall and still have that problem in closing by itself. Causes; The door can be installed with the hinge bound affect that keeps forcing the door to close by itself. The door can be installed in a plumb wall, but the hinge side of the door jamb out of plumb slightly in the direction of the wall and still be square and functional and without seeing a marginal discrepancy under the door margin to the floor. Not something I would write up, just a solution to the causes. If a client wants it fixed, there will be other things that he wants to fix also. I might just note that the door does not remain open and can be repaired by a qualified Carpenter. Not really a defect, just poor quality of installation. It would be called out in a New Construction build. In a 20 year old house, I would not get to excited about the problem. JMH
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks to all for your opinions.
Client was just curious, as was I However Barry Adair offered a quick fix and I let the client know Everyone is happy now Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Sure... go behind our backs!!! Care to share what Barry offered? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Jeff, I am sure Barry as usual gave some good advice, but would be curious also, just so I could attempt to keep up with him.
Got to stay on your guard with these silent advisors. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Attorney General's Opinion to TREC Request | mboyett | Texas Inspectors | 11 | 12/6/09 12:44 AM |
| According to the latest opinion polls... | jwilliams4 | Miscellaneous Discussion for Inspectors | 0 | 10/18/08 10:50 PM |
| Your Opinion Counts | pbennett1 | Thermal Imaging, Infrared Cameras & Energy Audits | 2 | 8/21/08 10:24 PM |
| Texas Atty. General Renders Opinion about Liability Insurance | bthompson1 | Legislation, Licensing & Legal Issues for Inspectors | 45 | 12/21/07 12:57 AM |
