mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have never seen this before. Any reason this is a problem? This is a strata complex. There is a 60 AMP rating on the service box. Thanks.
| Find an InterNACHI certified Wisconsin Home Inspector (and anywhere else in North America) |
Parallel service - no issue based on your pictures. . .
It is still a single service drop as the Popester has indicated.....just so happens they are running two different lines down which could mean many things....(2) different occupancies on a single service drop, or a par. drop for a single building...in any case it is typically fine.
Now the only potential issues I might note ( but cant see in the image real well ) is that the connection points need to be below the service head ( 230.53(E) ) Paul W. Abernathy |
| Service Drop Q | alarsen1 | Electrical Inspections | 11 | 2/25/07 9:45 AM |
| Service Drop Was Finally Removed! | jtedesco1 | Electrical Inspections | 1 | 12/1/06 2:40 AM |
| Service Entrance | jcampbell | Electrical Inspections | 9 | 10/30/06 12:14 AM |
| Service Drop and SEC | jpope | Electrical Inspections | 11 | 1/14/06 11:15 PM |
| Service entrance conductor | jjackson | Electrical Inspections | 30 | 1/7/06 5:05 AM |
