mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Any issue with this set-up?
200 AMP main service panel with 100 AMP breaker to first aux panel. 100 AMP aux panel has 60 AMP breaker to second aux panel. Thank you |
Service entrance is 240V. Two hot one neutral.
If the wiring has a homehandy look to it, I'd just note it as "amateur workmanship" and maybe advise a check by an electrician. |
| Service Panel Started Fire | mashburn | Electrical Inspections | 14 | 3/30/07 11:12 AM |
| Zinsco Service Disconnect Panel | pdickerson | Electrical Inspections | 7 | 9/16/06 12:59 PM |
| Service panel clearance | wwarner | Electrical Inspections | 13 | 8/12/06 1:07 PM |
| GFCI breaker in service panel | cobarr | Electrical Inspections | 11 | 4/17/06 10:59 PM |
