This is a new one on me. Anyone seen this before? What's your opinion? 1st photo is the feed from the main panel to the sub.
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It would have been just as easy to make it into a 240V panel. My guess is that someone just didn't understand the "concept."
Did the circuit have a neutral and a grounding conductor? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What was the amp rating of the aluminum feed cable, does the breaker match the wire rating and what were the loads on the subpanel? In the end, IMO, it is not a professional wiring job (from what I'm used to seeing in my area). I'd call it. |
It appears that they ran SEU (3 conductor) type SE cable instead of SER (4 conductor). That made them one conductor short. Maybe they initially planned on not separating the neutrals and EGC's as required. It is a poor design but probably code compliant if the calcuated load is less than or equal to the ampacity of the OCPD and the feeder conductors. I see a 70 amp CB, what size is that aluminum conductor?
If in doubt, recommend a state licensed electrical contractor evaluate panel and ensure safe to use as is!
I would think to make it safer they should have made it a single pole would you not think . ( thinking it may have drag if tripped)
I would refer this panel for sure. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
There's nothing "technically" wrong with wiring it as a 120V panel. It is, however, indicative of "unprofessional" workmanship, but I see no reason to defer it to anyone.
Based on what I can see, I would simply report is as a 120V panel in my report and move on. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
4 awg
“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 1/10/11 at 10:48 AM.. |
I agree, assuming no other issues present. At least they labeled it 120V. Similar to a subpanel fed with 3 wires instead of 4, all they have to do in most cases is label it "240V only" and ignore the missing neutral. This of course assumes that the loads are all 240V and no 120V loads present. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Under the 2008 NEC, if this is SE cable, then the CB is too large. Even under early code cycles the breaker may be too large unless there was a load calculation done to prove that the connected load is 65 amps or less.
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
