Old 11/29/11, 5:01 PM
Richard M. Ross's Avatar
Richard M. Ross Richard M. Ross is offline
Send a message via Yahoo to rross2 Send a message via Skype™ to rross2
Default 15 amp Branch ckt double tap
I have a 15amp breaker with a copper solid conductor and an aluminum stranded conductor double tapped. The breaker is rated for AU/AL, however it does not appear to be rated for a double tap connection. There are no vacant breaker positions. Is there a replacement breaker to accommodate this configuration, both solid and stranded? If not, I assume there is a breaker with the proper double tap for two solid conductors and if this is the case, is there an acceptable splice to pigtail a solid copper onto an aluminum stranded?
Richard Ross
Accurate Home Inspections of America, LLC
Cape Coral, FL 33914
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/29/11, 5:26 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: 15 amp Branch ckt double tap
You could use either of these. I would prefer the ones with the set screw:
Old 11/29/11, 6:14 PM
Sean Fogarty's Avatar
Those purple wire nuts sure are expensive.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 11/29/11, 6:55 PM
Jim Port Jim Port is offline
Unmoderated Guest
That may not even be stranded AL.
Old 12/1/11, 1:33 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Richard under no circumstances can you "Double Tap" a breaker. Your issue is not how to put the 2 dissimilar wires together as that is a violation. You need to only report the issues you found and not try to come up with a recommendation for correction. However to correct that issue they either need to find a "Cheater" or tandem type breaker rated for that panel or set a sub panel next to that panel to allow for more physical breaker spaces. Either way they need a Licensed and capable electrical contractor to asses and correct the issue.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 12/1/11, 5:19 PM
Double tapping is ok if the breaker is rated for double tap. And so far from my research, stranded wire maybe used on a breaker. Therefore It appears you could have a double tap on a double tapped rated breaker with one solid and one stranded.
Let me reword my question to eliminate the issue of discussing this with a client and ask if you ran across the above situation, (a double tap on a double tapped rated breaker with one solid and one stranded) would you call it as a defect?
The Realtor had asked me how much it would cost to repair and I told him if the second circuit wasn't needed, it could cost very little and that there might be some other options which would also be inexpensive, but only a licensed electrician can tell you for sure and the worse case would be adding a sub panel for an additional breaker.
Richard Ross
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Old 12/1/11, 6:09 PM
I agree that with the proper listed CB you can install more than one conductor (SQ D QO comes to mind). Also if the current circuit is operating without any problems it might be OK to simply splice the two conductors together and install a pigtail to the CB.
Old 12/1/11, 6:10 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
How about this fix. Leave the al wire on this breaker and pigtail the copper wire onto another copper.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 12/1/11, 6:20 PM
For example:
Larry Kage, CMI
231 929 3525
Aluminum Branch Wiring update jshishilla Florida Inspectors 6 3/16/11 11:11 PM
Bathroom electrical question sfogarty Electrical Inspections 8 2/2/11 5:35 PM
Double lugged breakers? dbook Electrical Inspections 7 4/30/08 12:35 AM
Double Tap Questions jkogel Electrical Inspections 6 6/28/07 9:46 PM
Double Taps... Here we go again rwand1 Canadian Inspectors 12 10/28/06 3:55 PM
