Old 9/22/10, 12:38 AM
Paul A. Kusic Paul A. Kusic is offline
Default 150amp Main to a 200amp distribution panel
Ok guys, i should now this one, but i am second guessing myself. I was discussing this with a buddy of mine and he got me questioning myself.
I have a 150amp main disconnect panel outside at the meter that leads to a distribution panel inside with its own main disconnect rated at 200amps. isn't the 150amp followed by the 200amp wrong? In other words is the 200amp breaker over sized?
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/22/10, 12:46 AM
Nick Gromicko's Avatar
Default Re: 150amp Main to a 200amp distribution panel
I would think the 200 amp breaker protects the panel, which can only suffer 150 amps at most anyway. I don't see a problem... other than someone, looking at the breaker, might incorrectly assume they have a 200 amp service.
Find a Home Inspector
Old 9/22/10, 2:09 AM
Christopher Currins's Avatar
The 150 amp disconnect is the only "main" disconnect. The service installation the way you describe can not draw more than 150 amps.
Christopher Currins
Certified, Licensed
Old 9/22/10, 4:34 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Other than the potential problem that Nick cited (not a code issue) the installation is code compliant.
Old 9/22/10, 8:37 AM
Kenneth Dolin's Avatar
Kenneth Dolin Kenneth Dolin is offline
You should take the NachiTV electrical course, it addresses that nicely
Ken Dolin
Kenco Home Inspections
WWW.Kenco.org
State of Florida Licensed Home Inspector HI 59
Old 9/22/10, 6:46 PM
Thanks, i was over thinking. Of course the 150amp main disconnect is going to regulate the draw to 150amps only.
Panel Questions - main, mid, sub lfoster Electrical Inspections 6 11/11/08 9:42 PM
Main and Sub Panel gheller Electrical Inspections 10 9/25/08 9:22 PM
Outlet off of Main Panel? jlevy Electrical Inspections 2 8/5/08 5:18 PM
Main at meter pole, distribution in home lfoster Electrical Inspections 7 7/17/08 10:31 PM
