I'm starting to see more advertisements for 1875W hairdryers like this one
http://www.walmart.com/catalog/produ...uct_id=3999276 Isn't 1875W too much for a bedroom circuit? Do breakers have a built in time delay that allows them to run for five or ten minutes with an overcurrent? If not, wouldn't the breaker trip immediately? |
Look at them like 5hp air compressors with 120v cords. It is a lie.
I put the amp probe on a bunch of hair dryers that say 1600, 1700 and 1800 watts. They are more like 1300 to 1400w. |
yeah but what about when it's 3 years old, and that little screen on the back is packed with lint, and dust. that alone will over heat a hair dryer and cause it to "trip" it's own little thermal switch. it cools down for 10 min. and you up and running again, but only for 3 min. how many watts does an 1800w hair dryer pull when stressed like that. maybe that's how they rate them, by the max for the thermal switch inside??
They won't pull any more power dirty than they would pull clean. When you "throttle" an air moving machine the current draw actually falls (think of how a vacuum cleaner speeds up when the hose is blocked).
I am not sure how they come up with these numbers and since the actual is less than the labelled they don't run into listing issues. |
ddelaney is a non-member guest and is in no way affiliated with InterNACHI or its members.
Greg, I would be inclined to disagree with this. Although the analogy of the vacuum cleaner is true, the hairdryer has purely resistive elements, which will have a higher resistance when less air is passed over them, creating higher power consumption. And, because the voltage is the constant (P=i*e), amperage also inclines proportionally. Therefore, the less air flow, the more wattage consumed. So make your ladies keep them puppies clean |
The reality is, if this element gets much hotter than the design temperature, the thermal fuse blows and she tosses the dryer. It becomes dangerous when some guy who is handy with tools jumpers out the fuse. |
I have heard and seen test results that light bulbs last longer if you don't turn them on and off. Rarely does a light bulb burn out while it is on; they always burn out when you flip the light switch on. So one then has to do the calculations of longer-lasting light bulb using more electricity because it's constantly on but buying fewer light bulbs versus shorter-lasting light bulb using less electricity but buying more light bulbs. I haven't done the calculations yet (and never will, Ms Margarta's demands notwithstanding), but I prefer to turn my lights on and off. As my wise ol' grandmother taught me, "If it is on, then it is using electricity." NACHI 2005 U.S. Member of the Year
The on/off thing refers to old style flourecents (ferro ballast). They take more current to start than they use running but I think the crossover time is in minutes, not hours.
As greg said most have a listing but usually pull much less, however we are to take into ACTUAL listing consideration when we wire for these items.
This is why the concept of hair dryers in the bathroom requires a 20A circuit...if you state it is just on the bedroom circuit then a problem lies their since it really depends on what ELSE is on and running on that branch circuit. Within the bathroom....in new construction the bathroom should have a 20A circuit minimum....and would allow the operation of the hair dryers with no problems...unless of course you were prior to 99 NEC when many put bathroom GFCI's and outside GFCI's on the same circuit.... But I digress.....gotta run......guys are calling and moaning I am not at the job Paul W. Abernathy |
I am not sure that is relevent to any real world experience. There may be a short spike on start up because the filiment draws more current until it is hot but that is a pretty small amount over the course of the average time you leave the light on.
If we were willing to say 500ms cycles was worst case and it was 50% greater for that 500ms the crossover time (when it becomes cheaper to turn off the light and take the "start up" hit again) is about a second and a half. |
| Lights Flickering while appliances start-up and while running. | Jeff Nunz | Electrical Inspections | 15 | 11/27/07 4:04 PM |
| How many gas/oil appliances can vent into 1 flue? | jberthiaume | Inspecting HVAC Systems | 11 | 10/17/07 10:09 AM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
