Old 8/11/07, 2:03 PM
Default 2 main disconnects outside
Overhead service went to a utility pole on which the meter and 150-amp main disconnect were located. Service then continued underground to home exterior where a second panel had a single 150-amp disconnect. feeders then went to home interior where a 100-amp sub-panel appeared to have no floating neutral.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 8/11/07, 3:10 PM
Default Re: 2 main disconnects outside
The pole is the 1st structure, the house is the second structure. With no parallel paths this is a 250.32(B)(2). The sub in the house is the problem
Arching Causes Main Breaker To Trip? msylvester Electrical Inspections 10 10/22/07 3:57 PM
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 6:24 PM
Manufactured home main pull abishop Electrical Inspections 9 4/25/06 10:02 PM
Main Electrical Shut-off? jpassailaigue General Inspection Discussion 10 3/24/06 2:19 PM
