Wtf?
OMG
What did the drop look like? Were there two, or just one.
If the property is zoned for two or more dwelling units, I can understand seeing two meters. However, there should be only be one drop and the gutter should have been visible in this photo. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What Jeff said
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Upgraded from ancient to semi-ancient (fuses?)
Steven Waskewicz Rest Assured Inspection Services, LLC. 719-510-7703 mobile all the time 719-495-7166 Fax. s_waskewicz@msn.com HVAC Lic. #10722 EPA cert.544143239730 www.restassuredinspection.com NACHIiid=NACHI06032370 |
Jeez, BK2!!! An experienced inspector should have seen one or two of these by now!!! |
Rental?
Demand water heater? Demand A/C system? Mother/daughter? There are lots of potential reasons for this. |
Bk you should visit the low rent areas more often what is the big deal I have 3 meters
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
When we installed a Heat Pump years ago, the power company was installing second meters for the heating/cooling only for a discounted heat/cool rate.
What gutter?
Well, it can be done like that also. Just a parallel service any way you look at it. . .
| Many thanks to Home Inspector Essentials for lending NACHI.TV meters. | gromicko | Miscellaneous Discussion for Inspectors | 1 | 4/14/08 8:08 PM |
| Moisture meters | relliott | Structural Inspections | 35 | 8/3/07 6:57 AM |
| Noise from Meters?? | mlong | Electrical Inspections | 9 | 2/3/07 9:08 PM |
| Carbon Monoxide and Moisture Meters | jlapointe | Canadian Inspectors | 3 | 12/21/06 12:51 PM |
| Watt Hour Meters | jtedesco1 | Electrical Inspections | 0 | 2/5/06 12:08 PM |
