Old 4/23/09, 9:06 AM
Paul A. Wancata Paul A. Wancata is offline
Default 2 prong receptacles
Is it a good idea to recommend to clients to update electrical receptacles to a 3 prong grounded outlet in living spaces such as family rooms, iving rooms, etc... to meet modern electrical requirements for cable,electronics,computers, etc... Also, has anyone used the Ideal circuit analyzer 61-165. i'd like to get some feedback. Thanks
Paul Wancata
Inspections Unlimited
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 4/23/09, 9:15 AM
Bob Elliott's Avatar
Default Re: 2 prong receptacles
I call them out dated and recommend upgrade.
Also a good clue to look for those cloth covered wires.
Old 4/23/09, 9:51 AM
Unless you are absolutely sure that each receptacle is able to be grounded, don't recommend a replacement with a three pronged recept. An electrician may be needed to upgrade each branch circuit where a ground is needed.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 4/23/09, 11:14 AM
James H. Bushart's Avatar
Home inspectors call out defects. This system, unless observed in a new construction or addition, is not a defect.
Home inspectors do not recommend remedies to the defects that they point out in their reports. They recommend that they be repaired or replaced by a qualified contractor.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 4/23/09, 11:24 AM
But you guys do mention the system as outdated....Yes?
Old 4/23/09, 11:31 AM
Jeffrey R. Pope's Avatar
I don't leave home without it, in fact, I have three.
The three-light tester does not give enough information and should not be your only tool for receptacle testing.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/23/09, 11:48 AM
I don't.
I will include a narrative that the two prong system is perfectly safe, will accommodate GFCI receptacles, and does not need to be replaced. I will mention the dangers caused by "adapters" and the possible inconvenience this system poses when using most modern day electrical appliances.
"Outdated" infers the need for replacement, which I do not recommend for anything that is not defective (with the exception of GFCI in wet areas).
James H. Bushart
314-803-2167
Old 4/23/09, 11:52 AM
jrivera's Avatar
jrivera jrivera is offline
Please Note: jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by jbushart View Post
I don't.
Good verbiage.
Mic
Old 4/23/09, 12:13 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
http://www.nachi.tv/episode42
Scroll to 4:45, Joe covers this nicely, and taught me allot.
Old 4/23/09, 12:32 PM
I don't.
So the whole idea of grounding was never needed?
Old 4/23/09, 1:43 PM
2-prong outlets are not a defect. It is errant and misleading, on our part, to state or to infer otherwise.
James H. Bushart
314-803-2167
Old 4/23/09, 2:52 PM
Randy D. Stufflebeem's Avatar
Randy D. Stufflebeem Randy D. Stufflebeem is offline
I agree with James on both quotes! Unless you are licensed to make that call and never worry about liability issues, I would stick with what a home inspector should report.
I often tell folks:
I am like the General Practitioner and the Plumber, Electrician, etc is like the Surgeon.
Everyone can separate the Doctor at the clinic and and the Surgeon at the hospital.
Old 4/23/09, 2:56 PM
You guys may notice I used the term out of date.
Anybody catch me saying defect.?
Hmm it is a defect only in new construction.?
Want to take that statement back after someone please defines defect for me?
Old 4/23/09, 3:09 PM
Not disagreeing with you Bob. Just saying I stick with more along the line of James's approach. Never thought you said "defect" and yes it can be a defect in more than just new construction. I have wrote them up when they were defective but never simply because they were two pronged.
Two prong receptacles. dryerson Electrical Inspections 20 6/27/08 3:01 AM
3 prong receptacle w/out equipment ground wire mbrown5 Electrical Inspections 4 8/24/07 1:55 AM
2 prong and 3 prong? gbrasseur Electrical Inspections 4 3/2/07 4:50 PM
2 Prong Receptacles dnasser Electrical Inspections 5 2/26/07 11:24 AM
open ground on 3 garage receptacles dnasser Electrical Inspections 14 10/30/06 5:53 PM
