Alright got to questions.
#1) Did a reinspection to day where I noted double taps in a panel. There solution, which is pictured, was to remove the double taps, wirenut them together and pig tail them with one single wire back to the breaker. Comments needed.. #2) On an inspection today found a panel (find a lot of them in this particular neighborhood) that had no ground wire from the panel or meter that attached to a ground rod. The realtor made the comment "Was it code at the time it was built?" Anyother time I have called this out they have fixed it without question. When did the NEC require a ground wire and what would be a good replay next time some realtor makes that comment. Thanks in advance! Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
#1) Perfectly acceptable, although sloppy.
#2) I have a 1940 NEC that shows a requirement for a grounding electrode. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 4/26/06 at 1:21 AM.. |
Complete safety (of my clients) override any code in my book. Let's say that the GEC just recently got adopted in 2003 due to related deaths. A building that was built in 1998, does not require a GEC?Attachment 3120 Last edited by dvalley; 10/7/07 at 5:41 PM.. |
I'd just recommend the grounding electrode for enhanced safety and let them do what they will. It leaves the code out of it.
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
[quote=jpope]#1) Perfectly acceptable, although sloppy.
I don't understand this. I was under the impression that if you double tap you are most likely allowing more than 12 devices per circuit. Sooooo, if a double tap is not allowed for this reason, how would pigtailing 2 circuits to the same breaker be "perfectly acceptable" Larry |
Larry,
Maybe it is a canada thing...BUT the NEC does not mandate the number of outlets or luminaries on a given circuit. That MATH is left to the electrical contractor to use CORRECT wisdom......WE hope anyway. Doing the SPLICE removes the issue of double tapping..and as you mentioned you still have all the items on that circuit on the same OCPD...just not in a double tap situation...... Hope that helps any... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
James D Mosier is a non-member guest and is in no way affiliated with InterNACHI or its members.
Pigtailing two circuits inside the panel is little different than connecting them in a junction box one foot away (or anywhere really).
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
so basicly the double tap issue isn't for the number of items possible on a circuit (let's face it, we all have a power strip with at least 4 things plugged into on outlet, or one of those 6 into 2 boxes) but for the fact that the screw on the breaker isn't designed for it.
ding, ding, ding. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
yeeeeeee haaaaaaaa. you can mail me my cash prize.
dspencer is a non-member guest and is in no way affiliated with InterNACHI or its members.
# 1 a solution.. No. The service box may not be used as a junction box. Recommend a mini double breaker installed is the proper fix if no room permits an additional breaker..
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Structural Inspections | 3 | 10/31/06 4:17 PM |
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Interior Inspections | 6 | 10/29/06 6:35 PM |
| For Sale Nokia N95 At Just $300usd | tonystores | Electrical Inspections | 8 | 10/28/06 4:39 PM |
| For Sale Nokia N80 For A Cheap Price Of $150usd | tonystores | General Inspection Discussion | 1 | 10/28/06 12:34 AM |
| For Sale Sidekick 3 For A Cheap Price Of ...$180usd | tonystores | Legislation, Licensing & Legal Issues for Inspectors | 1 | 10/28/06 12:31 AM |
