Old 10/2/12, 4:34 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default 20 amp breaker for water heater
20 amp breaker, with 10 gauge wire, installed on 50 gal. Whirlpool heater (upper left breaker).
Comments?
Thanks in advance.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/2/12, 7:05 AM
Robert Meier's Avatar
Default Re: 20 amp breaker for water heater
Probably too small but what is the heater wattage?
Old 10/2/12, 7:08 AM
I'm assuming 4500, no? Isn't that typical for newer, 50 g electric? Not 100% sure, though.
Old 10/2/12, 7:38 AM
If it's 4500 then the 20 amp will work but it won't be code compliant. A water heater of this type is required to be considered a continuous load meaning that the branch circuit needs to be calculated at 125% of the heater's rated ampacity.
4500/240 = 18.75 amps, will work on a 20 amp OCPD but,
18.75*125% = 23.4 amps, requires a 25 or 30 amp circuit.
Old 10/2/12, 1:53 PM
Mary Ann Chiquete's Avatar
Mary Ann Chiquete Mary Ann Chiquete is offline
Great information Robert, thanks.
Old 10/2/12, 2:10 PM
Christopher Currins, CMI's Avatar
Christopher Currins, CMI Christopher Currins, CMI is offline
Here's a good link, I like it anyway.
How to figure Volts-Amps-Watts for residential water heater
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Old 10/2/12, 2:30 PM
You're welcome, here's a few NEC sections to accompany my last post:
422.11 Overcurrent Protection. Appliances shall be pro-
tected against overcurrent in accordance with 422.11(A)
through (G) and 422.10.
(E) Single Non–motor-Operated Appliance. If the branch
circuit supplies a single non–motor-operated appliance,
the rating of overcurrent protection shall comply with the
following:
(1) Not exceed that marked on the appliance.
(2) Not exceed 20 amperes if the overcurrent protection
rating is not marked and the appliance is rated
13.3 amperes or less; or
(3) Not exceed 150 percent of the appliance rated current if
the overcurrent protection rating is not marked and the
appliance is rated over 13.3 amperes. Where 150 per-
cent of the appliance rating does not correspond to a
standard overcurrent device ampere rating, the next
higher standard rating shall be permitted.
422.13 Storage-Type Water Heaters. A fixed storage-type
water heater that has a capacity of 450 L(120 gal) or less shall
be considered a continuous load for the purposes of sizing
branch circuits.
Old 10/3/12, 5:38 AM
Joseph M. Whitt Joseph M. Whitt is offline
My 40 gallon has been on a two pole 20 for more than 5 years with no problem.
Mike Whitt
Contractor/Instructor
Old 10/3/12, 8:23 AM
James T. McGrail's Avatar
James T. McGrail James T. McGrail is offline
Great link !
I cant even guess what this is jjimenez Plumbing Inspections 11 4/6/12 7:38 AM
What wire size and breaker for heater??? Dan Bolton Inspecting HVAC Systems 3 12/17/10 7:51 PM
Water heater breaker sizing rgallahorn Electrical Inspections 15 9/8/07 1:57 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
