200 Amp Cutler Hammer Panel.
New Construction. New Installation. Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:34 PM.. |
Am I seeing that correctly (had a little wine tonight) - is that a 100 amp breaker installed on that box???
Also, hope you wore safety gloves and rubber shoes. |
Main Breaker is 200 Amp
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I can't see anything wrong, looks nicely organized for a new construction, given to the lower bidder electrician.
tom P.S. Seeing GEC going through those 1/4" with no clamps, req'd per 315.5C, is weird, but I'm sure if I make an issue out of it, Paul will come and beat me. |
315.5(C)??? No such Art./section. At least in '02 or '05. I just wonder why guys use 30/40 panels when space is not limited. |
tom |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like somebody took a little pride in doing a nice job instead of a rush job.
Who knows Speedy....probably was a contractors pack and they saved a few bucks on the panel possibly.
Thomas.....I wont beat ya....i just dont care anymore...lol.....no matter what i say I will get debated...even if I am right so....screw it...lol but I will say....the lowest bid is not always the sloppy work...or the neat work.....all depends on the pride of the electrician over cost in my book. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Example, I help build homes as a volunteer with Habitat For Humanity. I was happy to see that HFH uses trusses at 16"OC even though they are rated up to 24"OC. Less wavy ceilings in the future. Well went into a home half-mill plus to hang some ceiling fans. When I was in the attic routing new lines, I noticed the bare minimum code that was met: truss spacing, insulation, etc. Then when Opened boxes, I found electricians splicing through switches(back stabbed and terminal ed) to save a wire nut. In this example, you can see sometimes just caring is what counts and puts minimum work into excellent work. Still a nice looking panel. One thing I have, has anyone been 'commented' on by a AHJ about wires bundled so tightly? Looks nice though. tom |
Are the ground wires in twisted bundles under one lug?
sparks is a non-member guest and is in no way affiliated with InterNACHI or its members.
Was that what the original poster was looking for? |
The twisted ground wires was the focus of the original post.
Opinions vary by Electricians and Code Inspectors in this area with regard to this type installation. Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I saw the twisted stuff, that's ok, and it only looks like only TWO egc's per terminal screw. I believe (don't have a CH sheet with me), that up to two 'grounds' per terminal screw is ok.
As for the twisting, if I have to remove a circuit, sure I would cuss out the previous electrician, but the odds of that are very limited. tom |
The Cutler-Hammer CH panels are my normal brand, and they permit two ECG's of the same size under one terminal screw. This is a Cutler-Hammer BR panel, so I don't rightly know. If I had to guess, I'd say that they are the same. The twists aggrivate me, but it sure does make for a neat panel. As long as none of these terminal screws has three or more ECG's under it, it's a nice job. I know the installer spent a little extra time on this one. My personal work is a more of a blend of speed and neatness, which is necessarily required to maintain profitability.
| Sq D 200 amp panel with Cutler Hammer Breaker | lfoster | Electrical Inspections | 7 | 6/28/07 11:06 PM |
| Great New Products- Cutler Hammer | pabernathy | Electrical Inspections | 8 | 3/10/07 8:46 PM |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
