There is a first time for everything...
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Many times all that is needed on a 100 amp service is more breaker space.
Are you thinking there is an issue with this install? |
The problem was this was a 3000 sq foot farm house including a 4 bedroom 1 bath 2nd floor addition with a 4 ton A/C, electric range, 80 gallon water heater, Insta-heat supplemental water heater, electric dryer, well pump, plus the typical small kitchen appliances including a dishwasher. Forgot about the whirlpool tub and the outdoor pool. Oh, yeah, there was a pump for the septic tank but the nameplate was not visible....
But no one would have known that without me mentioning it. Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Looks like time for a Licensed Master to do a load calculation and most likely do a heavy up to the service.
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com www.MarylandRadonTesting.org State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
That's what I put in the report. Attached is a guesstimate I put together.
| Main Electrical Panel Behind a Kitchen Cabinet | cng1 | Electrical Inspections | 4 | 4/24/12 9:20 AM |
| Cabinet Bolts | jleahy | Interior Inspections | 7 | 3/5/12 11:18 AM |
| steel cabinet | sgoddard | Electrical Inspections | 3 | 1/14/11 5:51 PM |
