| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
200 meter. IMO, should have 400 for 2-150 mains. Suggest to the owner to check with utility company for verification of meter size and fuse size behind the meter itself, if any. Appears to be a possible double-tap behind the meter.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
IMO it's 150 + 150 or 300 amps. The meter really has nothing to do with the service size. If it's too small then it's the POCO's problem. However that doesn't mean that there aren't other potential issues visible in the photo.
It looks like a paralell 150A service - essentially, two separate 150 amp service-circuits. It appears that one breaker feeds the breakers within the service equipment, while the other feeds an additional panel.
Regardless of the rest of the equipment, the meter rating has no bearing on the capacity of the system. Meters are the responsibility of the utility company, and their rating should be ignored by home inspectors. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I state the amp service on every report, because most insurance companies always ask. Never missed in 10 years, 3,800 inspections. Inspectors are different.
A few other observations. If you take a look at photo #1 you'll see a graphic depiction of a double lug at the meter. Since everything on the line side of the two CB's is factory installed I would rule out the possibility of a double tap. The label says for underground service entrance only so I would note that if it were overhead. Also the entrance of the SER cables is somewhat suspect. Is that a raceway in the upper right corner? If so how long is it since more than 24" would bring about derating. Also depending on the code cycle, derating issue and the conductor size the SER maybe undersized for 150 amps. |
What you have there is a 300 amp service. The 200 on the meter means nothing as to the size of the service. Mike Whitt Contractor/Instructor |
From NACHI's Online Education: How To Inspect Residential Electrical Inspections
Calculating Available Amperage In many cases, the listing information about a home is incorrect regarding the service amperage because brokers or owners rely solely on the size of the main breaker or fuse. Many people are also under the mistaken impression that the available amperage is the total of the individual breakers or fuses in the service panel. The correct way to determine the available amperage is to determine the ampacity of the lowest-rated or the weakest link of the following components:
Example #1: A 200-amp service lateral, a 200-amp meter and base, a 175-amp-rated SEC, a 150-amp-rated panel, and + a 125-amp service disconnect = A 125-amp reportable service supply Example #2: A 150-amp service drop, a 60-amp meter and base, a 150-amp SEC, a 100-amp-rated panel, and + a 100-amp service disconnect = A 60-amp reportable service supply A home inspector getting this wrong could potentially end up paying for a service upgrade costing several thousand dollars. Chad Norlen SEI Inspections InterNACHI Member Certified Professional Inspector HVAC Journeyman - State of Idaho EPA Certified Universal Technician |
The meter rating is irrelevant - period. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
And I would disagree that in terms of Home Inspectors it does indeed have some relevance but not really a sizing factor you hang your hat on...as it could simply be an error. You use it to confirm things sometimes but that's all. However, as stated in my course as well as others the meter is one of the things you can THROW OUT in your equation if you have enough elements to support your basic findings.
My eyes are not doing well here as i can't see the 150A on those mains....I just assume it can be up to 200A each per the nomenclature provided. However, if they are 150A then you indeed have a 300A service based on the Main Circuit Breaker, The Size of the Conductors. However, there is one important point I would like to make beyond this... If these are the service disconnects (which I am sure they are) and the SER cable running from each of these panels to their respective remote distribution panels are not serving "all loads" that are part of or associated with the dwelling would not be allowed to use allowance of Section 310.15(B)(7) and the associated table. Just a tidbit of information.... Paul W. Abernathy |
Los Angeles Department of Water & Power (LADWP) has thousands of "15 amp" meters still in use on services from 60 to 400 amps.
Meter ratings are not a limiting factor for determining service capacity. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Now....knowing the meter cabinets sizes, shapes and so on WILL assist you in some cases....but that is what we mean when we say meters...not the meter itself....but the meters enclosure more correctly. Paul W. Abernathy |
Agreed.
Paul W. Abernathy |
| Service size | acox | Electrical Inspections | 6 | 9/5/09 2:40 PM |
| Infrared Inspection Service | jwarner | Thermal Imaging, Infrared Cameras & Energy Audits | 25 | 7/28/09 7:32 AM |
