I understand the NEC residential codes for 2008 includes the following changes:
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
1- Not all of these are required to be GFCI protected. In the kitchen only those above the counter top and only in the unfinished basement. In the garage everything will require GFCI protection 2- Not all in the home will require arc-fault. Kitchens, unfinished basements and garages as well as all devices installed outside are not included 3- All devices installed as outlined in 210.52 will require tamper resistant devices 4- Yes, a lot of states are amending the 2008 code as we speak 5- To the best of my knowledge there are no tandem arc-fault breakers on the market today. Panels will no longer be limited to 42 circuits but the limit was not lifted for the installation of arc-fault breakers 6- The combination arc-fault receptacle (this is parallel and series arc devices) was released a few years back but was recalled. I have no knowledge of the manufacturers doing combination arc-fault and ground-fault in one device. |
I did note "all other circuits will be AFCI", following the line regarding kitchen, garage, basement etc.
Here's a good, free .PDF 2008 NEC code change summary with lots of pictures:
http://tnblnx3.tnb.com/emAlbum/album...2008_lr_bm.pdf |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thank you Marc.
Yea. Thanks Marc. Downloaded the pdf and started looking through it. Nice.
| Garage/house fire door | Steven C. Meyer | General Inspection Discussion | 15 | 2/5/08 7:06 AM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
