Old 10/30/10, 8:56 AM
Calvin D. Cowles's Avatar
Calvin D. Cowles Calvin D. Cowles is offline
Default 220v neutrals
Should the 220 volt neutrals be on the same buss as 110v neutrals in a sub-panel?
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/30/10, 9:08 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: 220v neutrals
One you go past the service disconnect the grounded and grounding conductor must be separate, this applies to the sub panel. This would apply to both 120 volt and 240 volt circuits.
Old 10/30/10, 9:17 AM
So how do I tell if the "white" wires on the 240 are neutrals or grounds or needed at all?
Old 10/30/10, 9:20 AM
Just wondering, since it's hard to tell from the photo but where does that white conductor originate? Does it come from a cable or is it a pigtail from a circuit breaker?
The white conductor should never be a grounding conductor and should terminate on the neutral bus in a sub panel.
Old 10/30/10, 9:22 AM
There are 3 240v circuits and 3 white conductors (black and reds connected to breakers) connected to the ground buss.
Old 10/30/10, 9:45 AM
Since this a subpanel the neutrals must be connected to the neutral bus in the panel not the equipment grounding bus. By connecting them to the EGC bus neutral current is now flowing on the EGC of the subpanel feeder back to its source. Under normal conditions current should never flow on the EGC.
Old 10/30/10, 10:30 AM
Robert's got it...
Larry Kage, CMI
231 929 3525
Old 10/30/10, 11:08 AM
Jeffrey R. Pope's Avatar
Robert is correct, but to help clarify -
The neutral conductor of a 240V circuit can/will carry current from the unbalanced circuit. So even in a 240V circuit, the neutral is a current-carrying conductor and must remain "ungrounded" until it has returned to the service equipment.
Most 240V circuits installed today will require four conductors - H+H+N+G.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/30/10, 11:35 AM
Thanks everyone!!!
Old 10/30/10, 11:53 AM
Robert Ernst Robert Ernst is offline
In your picture I see other nuetrals and grounds and the terminal it's on looks green in the picture. So it looks like they are sending the white wire to ground since in subpanel the nuetral and ground should not be bonded. It is ok to have 115 and 240 terminate in the same place. You don't say what it's running but things like stoves and dryers now require a 4 wire system since they have 115v controls and with a 3 wire it would have a false ground. Either way in your picture it looks like there is at least one issue going on.
Old 10/30/10, 8:06 PM
House built in 1990. Do you recommend to your clients upgrading old 3 wire (3 prong plugs for dryer and stove) to 4 wire systems? The 3 circuit is the AC condenser.
Old 10/30/10, 11:12 PM
No, I do not.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Aluminum Wiring for 220v. circuits? Unregistered AskNACHI.org Inspection Questions Forum 30 9/6/09 11:05 AM
Main panel grounds & neutrals jfrederick Electrical Inspections 15 3/1/09 10:04 AM
pole on double tapped neutrals rdemott Electrical Inspections 10 11/16/08 10:49 PM
Neutrals nbhi Electrical Inspections 8 8/9/08 1:10 AM
Electrician signs off 'ganged neutrals'...now what? mgault Electrical Inspections 16 6/2/07 11:09 PM
