I understand that in some 220 VAC applications, the neutral can be sized smaller than the conductors supplying power to the device. But I must admit I've never seen this type of installation before.
100 Amp primary distribution panel with a 60 amp remote distribution panel below. The panels are bonded and the bonding screw on the remote neutral bar was removed. No equipment grounds or neutral conductors present in the remote panel. The label on the remote panel state the 220 VAC circuits supply power to the electric baseboard heaters on the second floor. The conduit was EMT. If neutrals are required, do they need to terminate in the same panel as the source? Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Phase to Neutral gives 120 volt. L-1 to L-2 gives 220 volts.
You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 7/31/11 at 9:14 AM.. |
That's what I thought, but what about the two 110 volt circuits on the right side of the panel? Still no neutrals... and the ground is the EMT?
Need more info. Does the EMT that goes out to feed the 120 circuits have any white wires in it? If not they are likely using the EMT for the neutral return. That's a no go. I'd call it as "requires repair by qualified persons". It would be interesting to open the outlets on the 120 circuits to see what's being done. They would have had to tie the neutral on the receptacle to the metal box for it to work. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Maybe a handle tie is missing for the two single pole breakers which feed a 240V heating element.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
I thought about that. The branch circuits are two different colors and are routed through the main panel and different conduit. I did not pull apart the heater to verify the wiring (going above the SOP) or verify if the baseboard heaters are 220 VAC or 110 VAC. There are no neutrals in either case but it might be possible that the neutral(s) for these two circuits were terminated in the primary panel. That was the reason for the second half of my first question. Do the neutrals have to be terminated in the same panel as the source?
Greg they are all marked Electric Heat.
I think you may be missing a handle tie as in 4 220 circuits. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Baseboard Heaters | bhartley | Inspecting HVAC Systems | 11 | 4/8/07 2:37 PM |
| Water heaters in attics | phughes | Plumbing Inspections | 1 | 1/11/07 11:08 AM |
