100 amp service...cord is about 8 ft long connected to a 30 amp breaker.
Is this an electrical code violatation? What woud be the write up? ![]() ![]()
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sure does not look like it could carry 240 amps. I'm confused. You may have meant volts. Still does not look right but I can't blow up your pictues to really see much. Can't imagine this conforms to any current code.
Keith Runquist, CMI |
In most jurstictions you can not use a extension cord for perminate wiring. It should be hardwired with a 22o volt approved outside outlet.
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
I have seen that done a few times so people can hook up a parked motor home, it's just plain wrong. The conductors should be in an exterior rated conduit terminating at an approved exterior rated 240v receptacle.
Lots of electricians have been reported to improperly installing RV oultets. 30 amp RV's use only 120 volts. The 50 amp RV's use 240 volts. The size of the 30 amp outlets leads people and yes, some electricians to connect them to double pole 240 volt breakers when it should be single pole 120 volt. If you see a new install it may not have been used to fry an RV yet so make sure it is 30 amp 120V or 50 amp 240V.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
It's as simple as that. . .
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Panel Questions - main, mid, sub | lfoster | Electrical Inspections | 6 | 11/11/08 9:42 PM |
| Zinsco Main Panel | gmacandog | Electrical Inspections | 3 | 8/14/07 12:23 AM |
| Main disconnect at meter instead of main panel. OK? | kshepard | Electrical Inspections | 14 | 11/8/06 6:24 PM |
