Old 1/13/09, 1:42 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default 240 volt check, Question.
As Home Inspector how do we check the 240 volt dryer outlet ?
Is there a tester similar to the device we stick into the 120 volt outlet
to check for correct wiring ?
David
Old 1/13/09, 1:56 PM
Jeffrey R. Pope's Avatar
Default Re: 240 volt check, Question.
Use your NCVD to verify two 120 volt contacts.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/13/09, 2:53 PM
Michael Larson's Avatar
I use a Wiggy
Michael Larson
Hudson, WI
[/I]
Old 1/13/09, 2:55 PM
James F. McKee's Avatar
Originally Posted by mlarson View Post
I use a Wiggy
Same Here...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 1/13/09, 3:06 PM
The wiggy (or similar device) is certainly more reliable and accurate, but the NCVD is quick and simple for determining if voltage is even present. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/13/09, 3:16 PM
Agreed.
Michael Larson
Hudson, WI
[/I]
Old 1/13/09, 3:23 PM
it certainly is and probably all that is necessary for Our purpose...I just happen to have had the wiggy for a couple thousand years so i use it....just habit.....
Jim Mckee
Amherst, Ohio
Old 1/13/09, 3:35 PM
Thanks everybody....
Old 1/14/09, 8:57 AM
With a Wiggy you will be able to verify grounding, with a NC tester you will not.
Procedural Inspection Checklist bgromicko Electrical Inspections 11 3/8/08 11:47 PM
Procedural Inspection Checklist bgromicko General Inspection Discussion 0 3/8/08 10:40 AM
inspection procedural checklist bgromicko Electrical Inspections 24 3/2/08 10:00 AM
