Old 10/19/06, 12:30 PM
DSuelflow DSuelflow is offline
Please Note: DSuelflow is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 3 Panel Setup
I came across this first timer yesterday and was wondering about its setup. The main disconnect (P1) is in it’s own box, making the others “subs”. The older sub (P2) is the original two-wire box and the newer one (P3) handles all the newer three-wire circuits. In P2 there is a 220 circuit in the lower right corner with the ground wire attached to the neutral buss, is this kosher? Don’t the neutrals and grounds need to be isolated in P3? There are plenty of other issues that an electrician will be called in so I’m covered, but I would like to explain it in my report in an intelligent way that covers the bases. Many thanks in advance from a long time fan.
3-panel-setup-2061-full.jpg   3-panel-setup-2061-p1.jpg   3-panel-setup-2061-p2.jpg   3-panel-setup-2061-p3.jpg
Old 10/19/06, 12:36 PM
Jeffrey R. Pope's Avatar
Default Re: 3 Panel Setup
Neutrals are not to be grounded at any point other than the service equipment. Exceptions apply, but not in this case. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/19/06, 1:20 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Unusual to use a fused disconnect like that in a house.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
