Old 12/15/10, 5:13 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default 3 Phase comments please
Did a recent inspection that appeared to have 3 Phase electric service/panel. I don't see this type of install very often and don't know much about 3 Phase. I didn't see much wrong with the service feeds themselves, but was wondering what I can tell my client about the 3 Phase service, i.e. advantages/disadvantages. The home had electric baseboard heat (also very unusual in this area), and I assume the electric draw has a lot to with the reason it has a 3 phase service. Any comments would be appreciated.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/10, 5:33 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: 3 Phase comments please
I would guess that it's a 3 phase, 208Y/120 volt service. (A digital multi-meter could easily confirm this). There are some minor problems and looks a little sloppy but from the photos' it doesn't appear that there is anything dangerous. What do you want to know about 3 phase systems?
Old 12/15/10, 6:08 PM
What are the advantages/disadvantages if any in a single family residential dwelling, does it save on electric cost, what would be the purpose it was used in the first place?
774 Manor Road
718-514-3393
Old 12/15/10, 6:33 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Very colorful. Looks like candy cane.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 12/15/10, 6:34 PM
Michael Larson's Avatar
Did they have a large work shope with 3-phase equipment or a kiln?
Michael Larson
Hudson, WI
Old 12/15/10, 7:04 PM
Nope.
774 Manor Road
718-514-3393
Old 12/15/10, 7:08 PM
Bob Elliott's Avatar
Three phase when used is better from a economic standpoint and more efficient.
But that is only if their are motors running taking advantage of it.
Old 12/15/10, 7:41 PM
There really is little advantage for a residential dwelling. The big disadvantage is that most residential equipment is designed to operate on 240 volts. That means that any electrical heating appliances listed at 240 volts and operating at 208 volts would have a significantly lower power output.
Old 12/16/10, 3:44 PM
Bob Electric Bob Electric is offline
Please Note: Bob Electric is a non-member guest and is in no way affiliated with InterNACHI or its members.
One advantage is you have 3 buss bars suppling 3 = 200 amp legs,instead of single phase only suppling 2 - 200 amp bus bars.More available wattage.More power.
Old 12/17/10, 5:28 PM
agallatin agallatin is offline
Here your monthly minimum is so great with three phase , that you would still end with the same maybe even hire bill per month .
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 12/17/10, 5:42 PM
Some years ago, HVAC systems above a certain size were only available in 3-phase models. Consequently, I sometimes see a 3-phase service in larger, medium-aged homes. I don't know of any reason someone would request (or the power company would agree to install) a 3-phase service unless the home's equipment required it. However, once installed, it is usually not practical to change it even if the equipment that required it has been replaced or removed.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 12/20/10, 10:36 PM
Timothy R. Wendorff Timothy R. Wendorff is offline
More importantly...is this a Zinsco panel? (Breaker handles kind of look like Zinsco's)
Old 12/21/10, 5:04 AM
Did Zinsco make 3 phase equipment? Looks like GE or Murray to me.
Old 12/21/10, 9:17 AM
The blade type bus bars are what you want to look for:
Larry Kage, CMI
231 929 3525
Old 12/21/10, 2:15 PM
It was a Murray panel per the label. I thought the same thing about the breakers and even questioned it in one of my other posts.
774 Manor Road
718-514-3393
Infrared Sample reports dvalley Thermal Imaging, Infrared Cameras & Energy Audits 26 1/1/08 8:40 PM
For those in favor of licensing gbeaumont Legislation, Licensing & Legal Issues for Inspectors 70 5/21/07 3:09 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
