Old 11/9/10, 4:27 AM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Default 3 prong plug how do I write it up?
I often see 3 prong plugs wrongly installed. but yet have to do a proper written report as a certified residential building inspector.
I need clarification.
Sorry but the photo examples did not come up right.
The photo is correct in this image.
I see the opposite 50 percent of the time.
[ATTACH]Attachment 40059[/ATTACH]
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/9/10, 4:46 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Default Re: 3 prong plug how do I write it up?
Not sure about Canada but here if you're saying that the ground on the top (up) is incorrectly installed then you're mistaken. There is no NEC wording that dictates the orientation of the ground prong on a receptacle. Is this what you want to write up or is it something else?
Old 11/9/10, 5:52 AM
Thank you Mr.Meire
I know the right way is to have the ground up as to avoid contact from any ( conducting ) object falling down the wall plate and would be moved and somewhat unable to touch both bottom connections simultaneously.
If not installed correctly it might case a short or worse injury and death.
Old 11/9/10, 6:35 AM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Originally Posted by ryoung7 View Post
Thank you Mr.Meire
As Robert stated, there is nothing in the NEC regarding orientation.
The theory that the ground prong will stop shorts, is good, providing that you are using a three prong plug.
For two prong plugs, it doesn't really matter.
Old 11/9/10, 6:36 AM
Wayne B. Wilson's Avatar
Robert
I think it is a preference, In commercial you often find the ground on top and residential on the bottom
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 11/9/10, 7:17 AM
Thank you Mr. Van De Ven.
I have to look because its my understanding that homes of a certain age must be fitted with 3 prong.
Old 11/9/10, 8:12 AM
Joe Funderburk, CMI's Avatar
If it was sideways, as on many cabinet back-splashes, would that be wrong also???
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/9/10, 8:17 AM
I am asking a civil question.
Like to here and have read sensible ones SIR.
Old 11/9/10, 8:29 AM
See my answer above.
Also, the OP is in Canada. Canadas codes vary from the NEC in several areas.
As for grounded receptacles, I'd have to look that up Robert.
1975 NEC section 210-7, was the first year that all 15 and 20 amp receptacles in residential occupancies, were required to be the grounding type.
Old 11/9/10, 9:08 AM
Thank you Mr.Van De VEN.
That is what I am asking for.
I have a code book and more questions to ask the RBQ before I set out on my new carrier.
Ontario code and going out this week to ask the government how up to date it is.
Mr.R Coole was kind to give it to me.
He is a class act.
Thanks all.
Old 11/9/10, 10:15 AM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Robert,
Time was that the ground being on the top was indicated on the receptacle itself, with the word "top" at the end that the manufacturer recommended be unstalled skywards. In time, the word was removed from the pressing.
As to Joe Funderbunk's question, although tounge-in-cheek...it is a valid one.
No need to have such a large chip on your shoulder.
Old 11/9/10, 10:27 AM
Jeffrey R. Pope's Avatar
In new construction, the one receptacle in a room where the grounding pin is on top, is the receptacle controlled by a wall-switch.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/9/10, 10:29 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
I see that a lot here.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 11/9/10, 10:48 AM
Marcel Gratton's Avatar
If the receptacle was posidioned sideways then the neutral should be up. In Gatineau, most receptacles are positioned with the ground up.
On The Level Inspection
Gatineau, Québec
Old 11/9/10, 11:27 AM
Michael Larson's Avatar
Originally Posted by jfarsetta View Post
Robert,
I worked several different construction projects in the same hospital over 2 decades.
Depending on the date of the new building project, they were installed one way or the other.
Michael Larson
Hudson, WI
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
HELP! What do you call a 3 prong male plug with a cord. gromicko Electrical Inspections 5 1/9/09 12:33 AM
2 prong and 3 prong? gbrasseur Electrical Inspections 4 3/2/07 4:50 PM
Two prong outlets and GFCI's crichiii Electrical Inspections 8 3/15/06 10:41 PM
