Have any of you ever seen this...
I was inspecting a condo the other day and found the following at an AFCI protected receptacle in a bedroom... *3-prong tester indicated correct polarity and ground *Idea analyzer indicated correct polarity with no ground (not a false ground) *Idea analyzer successfully tripped the AFCI Any idea what's going on? David Sorge (USN Retired) FL License HI142 Infrared Certified Thermographer Inspect-It 1st of Northeast Florida Serving Jacksonville and surrounding communities 904-484-4847 dsorge@inspectit1st.com http://www.dsorgeinspects.com http://www.linkedin.com/profile?view...US&trk=tab_pro We see RED...InfraRED When we see RED... You see $GREEN$ Ask us how? |
If the 3-light tester has a dim ground indication that is a fault condition (high resistance). This may not be noticeable unless you are tuned into looking for it.
The other tester probably indicates "no ground" if the ground resistance is above a certain level. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I only use 3-prongs as a quick check to see if power is present, and when testing gfci/afci as a visual on multiple receps. Don't trust them for anything else. Seems like I had to replace them all the time. Stick with the analyzer. Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
A grounding connection is not needed for the AFCI testing feature to perform its function and trip the breaker. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| TPI 712 Flue Gas Analyzer | bsmith | Inspection Classifieds | 1 | 3/31/09 6:54 AM |
| Two Prong Outlets | jallingham | Electrical Inspections | 22 | 6/27/07 2:07 AM |
| 2 prong and 3 prong? | gbrasseur | Electrical Inspections | 4 | 3/2/07 4:50 PM |
| Two prong outlets and GFCI's | crichiii | Electrical Inspections | 8 | 3/15/06 10:41 PM |
