Is there an NEC or other national code that dictates that the control of permanent lighting must be by two 3-Way switches or motion sensors for areas other than staircases? I am curious about long hallways and rooms like hallways where it is often entered from significantly spaced opposite ends (ex- my kitchen has the rear entrance door and the basement staircase on one end and the hallway entrance to the kitchen on the opposite end 15 feet away). It makes sense for safety reasons that my kitchen has a 3-Way controlled fixture but I'd like to hear what NEC and IRC have to say.
Nick,
This doesn't directly answer your question but is good info anyway for a similar issue . Perhaps some of the code guys will address your question directly. The attachment below is from Mike Holt's site http://www.ecmweb.com/nec/electric_stumped_code_3/ which is very useful for electrical questions.
And thanks for the link Michael.
By the way, where were you on the day of the WiNACHI Well Sampler Course? You missed out on an inexpensive yet highly informative and enjoyable course. |
According to David Nice, one of our upcoming seminars is slated for the Eau Clare area. That's not too far away from you?
It is an inconvenience issue, not a code issue. There are retrofit options that do not require rewiring but the devices are fairly expensive and most require a neutral in the box.
| Competition Act in Canada must whatch out for up 1 Million fine! | jkoong | Canadian Inspectors | 12 | 9/8/10 4:59 AM |
| Lights Flickering while appliances start-up and while running. | Jeff Nunz | Electrical Inspections | 15 | 11/27/07 4:04 PM |
| Lights & GFCI Outlets | thejnicki | Electrical Inspections | 14 | 2/28/07 3:48 PM |
| Lights & switches | dmacy | Electrical Inspections | 21 | 1/27/07 1:15 PM |
