I haven't seen seen this before, an oldler electric range and a 30 amp breaker with 10 ga wire. I didn't pull the range out, nor did I find an owner's manual. How common is this? If at all.....
"He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Hope this helps, Chris Christian Mettel Certified Home Inspector Aurora, Ontario 289-221-4744 iNachi ID#06022187 www.buildingdetective.ca Aurora Home Inspection |
Agreed Christian, I wish I would have read the manufacturer plate that would have had the amp and watts, volts etc. They are going to replace it and install a gas unit anyhow....From what I understand it might be fine for a 24" apartment size unit.......
If they do switch over to gas they can simply convert the 30 amp circuit (new receptacle and CB) to a 15 or 20 amp circuit to supply the 120 volts needed by the gas range.
| Federal Electric 100A standalone main breaker -- OK or problematic? | fbartlo | Electrical Inspections | 16 | 9/6/10 5:17 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Electrical Safety Media Center | jtedesco1 | Electrical Inspections | 1 | 3/15/08 8:18 AM |
