Old 3/5/10, 4:58 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default 30 amp stove/oven breaker
I know I've posted about this before, but can't find the info. Just as easy typin a new post, than using the Search feature.
Anyway, can a 30 amp breaker be used with a stove/oven? I typically see 40 and 50. Manufacturer requirements?
Thanks in advance.
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/5/10, 5:07 PM
Doug Edwards's Avatar
Default Re: 30 amp stove/oven breaker
One thing I have learned is that just because a breaker is labeled does not necessarily mean it is correct. I find mislabeled breakers all the time so now I check to see what circuit t is actually protecting.
In answer to your question; typically an electric range will require breaker protection higher than 30 amps. You will need to check the manufacturers' plate, usually on the side of the storage drawer frame.
- John Stuart Mill
Old 3/5/10, 5:08 PM
Thanks in advance.
What does the name plate on the appliance say?
Larry Kage, CMI
231 929 3525
Old 3/5/10, 6:29 PM
I didn't check any data plates.... just a regular ole' stove/oven. What would you say?
Old 3/5/10, 7:09 PM
James F. McKee's Avatar
I've seen cook tops on 30...full range only see 50 here
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 3/5/10, 11:35 PM
Jeffrey R. Jonas's Avatar
Is there any harm in having the circuit on a 30 ... other than nuisance tripping?
Old 3/5/10, 11:40 PM
Bob Elliott's Avatar
No unless the conductors are even smaller, like under 10 gauge.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Re-Inspection apolillo Electrical Inspections 7 11/14/09 7:01 PM
Breaker Question mhawley Electrical Inspections 5 1/14/08 3:25 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
