Square D panel that was updated with in the last 10 years. Aluminum wire going to servicing the AC condensing unit. AC service disconnect is fuses. I'm not concerned about the aluminum wire, but is the fused disconnect an issue?
Thoughts? How would you write this up on a 4-point? Reece D. Welch –BSA,CMI,CGC,CCC,HI,MRSA Certified Master Inspector® State Licensed General Contractor State Licensed Roofing Contractor State Licensed Home Inspector State Licensed Mold Assessor Offices: 121 S. DeSoto Ave Phone: 863-494-1560 Arcadia, FL 34266 Fax: 863-494-6233 www.HISofSWFL.com |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What do see as a problem with the fuses? At one time old AC units required fuse protection.
Fuses are perfectly acceptable.
The only issue I can think of is that some units say wire with copper only.
| Electrical Box Question - Referral of Nick Gromicko | Unregistered | AskNACHI.org Inspection Questions Forum | 3 | 5/30/09 8:01 AM |
| Electrical box question - posted by weary parent | Unregistered | AskNACHI.org Inspection Questions Forum | 0 | 5/29/09 8:45 AM |
| Electrical Question | mkyriacou | Exterior Inspections | 9 | 3/12/09 2:59 PM |
| Download the videos here all about physics and electricity | jtedesco1 | Electrical Inspections | 5 | 9/14/08 3:58 PM |
| 4 Point Inspection Electrical Question | rross2 | Electrical Inspections | 4 | 2/3/08 3:13 PM |
