If sub-panels have more than 6 breakers should it have a service disconnect or does that only apply to the main panel?
Thanks ahead of time |
Mike check out the thread under yours.
I just had that answered. |
Detached structure it does. Within the same structure NO main is required.
Yeah, I'm confused too.
Maybe I was not clear. |
I often wondered if anyone tried to invoke 225.32 exception 1 in the residence of a qualified person
That exception is mainly for industrial establishments with a central powerhouse. |
Even though you guys don't do codes this seems to be a hard sell. So here: II. More Than One Building or Other Structure 225.31 Disconnecting Means Means shall be provided for disconnecting all ungrounded conductors that supply or pass through the building or structure. |
Marc, it doesn't say that. I know I would have a hard time approving the installation but if the owner had placards on the subpanel and demonstrated he was "qualified" (licensed) I am not sure how I would justify the rejection if he fought it. The fact that any installation was compliant at the time of inspection does not guarantee that those procedures will remain in place or that it will continue to be supervised by qualified people. As far as I am concerned the exception guts the intent of the rule. |
Speedy, Not disagreeing, trying to understand. This code is not clear to me.
If the main panel is feeding the subpanel and there is a main disconnect (or 6 throw) in the main panel that doesn't cover the subpanel? Doesn't that count as means of disconnecting? Last edited by kgerhauser; 3/12/08 at 12:33 PM.. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Or perhaps a better question is what is the difference between a detached structure and (for example) a different level/room of the same structure? If that is not the logic, please disregard. </IMG> |
Here is the section where location is addressed.
So in English, he is trying to say the kill needs to be near the entrance of the conductors, for the structure.
Not really an answer but a statement of CODE. Seems to me it should be required since so many are mis labeled.(refering to the subs) |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Breaker Question | mhawley | Electrical Inspections | 5 | 1/14/08 3:25 PM |
| Electrical Guru Question? Breaker lock outs | pdoane | Electrical Inspections | 4 | 9/7/07 2:05 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
