Old 3/10/08, 10:08 PM
Steven L. Hatcher Steven L. Hatcher is offline
Default 60 Amp breaker Going to 100 Amp
I have a 100 amp sub panel with a 60 amp square D breaker, that leads to the detached garage with another 100 amp panel. That 60 Amp should be a 100 amp correct?
Old 3/10/08, 10:17 PM
James H. Bushart's Avatar
Default Re: 60 Amp breaker Going to 100 Amp
It is not violate anything for a main breaker to be of less amperage than the max in the box. If it is used for lights, it will probably be okay.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 3/10/08, 10:19 PM
Marc D. Shunk's Avatar
Banned
Nope. The breaker protects the wire leading to that subpanel. The "100 amp" rating of the subpanel is the max rating that you can feed it at. In other words, it's "heavy duty-ness". This is the same as saying that you may only carry a sack of groceries in a 3/4 ton pickup truck. You don't need to carry 3/4 ton loads in it just because it's rated that heavy.
Old 3/10/08, 10:20 PM
Jeffrey R. Pope's Avatar
Not necessarily. It can be, if the conductors are sized appropriately, but there is no rule that says it must be.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Breaker Question mhawley Electrical Inspections 5 1/14/08 3:25 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
