The iNACHI electrical course indicates that the stand alone circular meter bases are 60 amps. But it doesn't really indicate to identify that as an issue or not? Do you call that out and how would you word it?
This is on a small brick home built in the 50s. The set-up has multiple issues from what I can tell...anything I'm missing for my own educational purposes?
Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Where do you begin? I would guess if the meter is face level, then you could just about grab the service wires. The whole thing looks clapped out, and is past its prime. By today's standards there is no way that service (in good condition) could handle the power requirements for all the modern ammenities. That mess is an accident waiting to happen. Just recommend an electrician to futher evaluate.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net Last edited by sfogarty; 1/26/10 at 8:57 PM.. |
Agree!!! Double taps noted.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
The meter base is not a "defect," and unless your jurisdiction has different requirements, the clearances for the service drop only needs to be 10 feet.
That mess does not need further evaluation, it needs "Repair". In fact, it needs to be Replaced. You are correct to call for a service upgrade, and that will probably include a new larger meter can, but I would let the installing electrician design the upgrade. |
Thanks guys.
| City electrical inspector says move the meter and panel | cbottger | Electrical Inspections | 9 | 4/4/07 8:59 PM |
