Home with 60 Amp meter base has 200 Amp main breaker. Unsure of the copper conductor size, possibly less than 2/0. Any concern with the 60/200 ratio?
The meter base is an indicator, but not really reliable to determine service capacity.
Write it up as you see it.
The meter base is diffently to small. Round cans can be rated as high as 100 amps. The system is only as big as the lowest rated component. Not safe with a 200 amp main. |
I see a "Missing KO" seal at the top left, and a bad connection at the bottom left too!
Looks like this work was done by a non professional hack and bootlegger criminal! Last edited by jtedesco1; 6/12/08 at 4:39 PM.. |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Breaker Question | mhawley | Electrical Inspections | 5 | 1/14/08 3:25 PM |
| Electrical Guru Question? Breaker lock outs | pdoane | Electrical Inspections | 4 | 9/7/07 2:05 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
