mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I found this weatherproof enclosed 60 AMP circuit breaker in the crawlspace. The conductors coming out of 60 AMP breaker went to 100 AMP main breaker at service panel. I am trying to deterimine if the service is in fact a 60 AMP or if it has been upgraded to 100 AMPS.
The 60 AMP breaker states: Automatic trip is indicated by handle position midway between on & off. Restore service by moving to off and then on. It appears in the picture that the handle is in the 'midway' position and the home has power. Could this 60 AMP breaker be bypassed and the service is in fact 100 AMPS? Thanks for your advice. |
That whole mess is an abortion. Don't worry about how many amps it is. Just figure out some home inspector lingo to relate the fact that they really need an electrician PDQ.
Phew, thanks I was sweating it a bit...
I did refer to Electrician |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
How's that? </IMG> |
Unsafe to remove that under-trailer cover with the power on, lying on your belly. I would have checked in the area of the meters if it's a trailer park, that's where you'll find the real main breakers. The size of the service conductors to the panel inside gives you a clue as well, and in a perfect world, they'd be matched to the breaker. I estimated 60 A for a trailer one day, then on the way out, checked the meter cabinet, found a 50 A main in there. The neighbours had 40 Amp service! Pictured: a better than avg hookup, rated for 125 A, it's 100A service. Last edited by jkogel; 7/16/08 at 12:48 AM.. |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Help Determining Reportable Service Size | cbarrows | Electrical Inspections | 8 | 7/19/06 7:12 PM |
| Electrical Inspection with Temp. Service? | dandersen | Electrical Inspections | 16 | 6/27/06 10:41 PM |
