Old 7/21/07, 6:33 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
Default 60 amp service, very warm.....
Recent home inspection had a 60amp service. Slight scorch mark on dead front panel above drawer pull out fuse. It felt warm to the touch, infared temp had it at 108 degrees, the rest of drawer fuses were 73 degrees. Is this within acceptable temperatures?
Old 7/21/07, 6:42 PM
David P. Valley's Avatar
Default Re: 60 amp service, very warm.....
Absolutely not....Your average breaker or fuse cartridge should be at room temperature.
If your getting 108 degrees, recommend an Electrician to evaluate that particular fuse cartridge.
Did you open the cover to see what may be causing this heat build-up?
Old 7/21/07, 7:04 PM
More info:
http://www.nachi.org/forum/showthread.php?t=4390&highlight=breaker+temperatur e
http://www.nachi.org/forum/showthread.php?t=7760&highlight=breaker+temperatur e
Larry Kage, CMI
231 929 3525
Old 7/21/07, 7:20 PM
Thanks David, Larry. I did pull the dead front, but nothing stood out. I didn't pull the drawer, because of shutting off portions of the house. Bakalite looked worn and the pull and the face of the drawer looked well used! No# 4 copper service cable looked recent and the lugs were bright. Judging from the screwdriver slots on the lug screws he/she had some trouble getting them tight.
Old 7/21/07, 7:32 PM
Unmoderated Guest
This is simply not so.
Here is a quote from one of the threads linked above. It is written by one of the foremost experts in the electrical field IMO:
Originally Posted by Pierre Belarge
If you take a look at 310.16, the 75C column, you will see the F temps as well. If a conductor/breaker is loaded to the maximum current permitted, the conductor/breaker may reach this temperature (possibly 167F). So the conductor/breaker can actually be hot to the touch, well above the ambient temperature surrounding them.
Some breakers as they get older will buzz due to the pitting of the contacts, which also may increase the breaker temp. Depending on the load applied to the breaker in the picture posted, I would say the buzzing is from pitted or loose contacts, and the temp is not creating this problem. There are many variables, but this is my guess.
Old 7/21/07, 7:48 PM
So you're stating that "Hot" breakers and fuse cartridges do not need an Electricians' evaluation?
Old 7/21/07, 9:04 PM
Unmoderated Guest
I absolutely did NOT say that. Look at the line I quoted. I am saying that breakers above "room temperature" are not necessarily a problem.
I guess it is up to you guys to determine how hot is too hot.
Warmer than room temp is not an immediate red flag IMO. Literally hot to the touch is.
Old 7/22/07, 6:23 AM
Speedy,
Well, when I stated ...
"Your average breaker or fuse cartridge should be at room temperature. If your getting 108 degrees, recommend an Electrician to evaluate that particular fuse cartridge."
You stated
"This is simply not so".
That (to me) translates that I'm wrong in what I stated...IMO.
Old 7/22/07, 6:44 AM
Unmoderated Guest
David, PLEASE go back and re-read post #5. You are looking at it with your man vision. You are seeing only what you want to see.
I ONLY quoted the line about the breaker being at room temp. And please note the post was not edited.
Old 7/22/07, 6:51 AM
But you posted "This is simply not so," referring to my opinion.
Am I right?
Old 7/22/07, 10:00 AM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
David, there has got to be a way to market this special ability!
Possible example for your website:
Our Inspectors use "Man Vision**" during the course of the inspection. This special ability insures our observations are superior to those who use just plain vision.
Man vision tablets are available at your local NACHI mall outlet store. For added boost try our "Testosterone Vision" tablets. Not associated with "Women Vision" and "Estrogen Vision" which has been known to cause side effects such as outbursts of uncontrolled emotions, chronic crying and wild shopping sprees.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 7/22/07, 11:06 AM
Unmoderated Guest
Am I right?
Yes, I said your opinion that breakers should be at room temperature is flawed. I'm not sure how I could have been clearer.
Old 7/22/07, 11:07 AM
Unmoderated Guest
I'm not sure about you guys, but my man vision gets me in trouble all the time.
Old 7/22/07, 11:32 AM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here in AZ, most main panels are attached to the outside of the home. When its 110 degrees outside, all the breakers show elevated temps because they've been in the heat. I will scan each breaker and look for a deviation from the average to see if any of them are overheating becuase here, they are usually all hot to the touch.
Old 7/22/07, 4:37 PM
So, in your situation your room temperature would be the outside temperature. Right?
The sun is normally very hot and does actually heat up everything it reflects off of. So that would obviously make the breakers a tad warmer.
Oopps...I forgot, it's not a room.....Attachment 13342 I guess it must be an actual room to qualify for room temperature.
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Help Determining Reportable Service Size cbarrows Electrical Inspections 8 7/19/06 7:12 PM
Electrical Inspection with Temp. Service? dandersen Electrical Inspections 16 6/27/06 10:41 PM
