Surge Suppressor
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Thank you.
If it's a surge suppressor why does it look like it is meant to be monted in a recpectacle box?
In any case it is not supposed to be in the panel or unsecured and not doulble tapped in the manner it is. |
The TVSS is not installed in a compliant manner. A lightning strike may, and probably will, whip it about in the panel. The metal pieces on it may come in contract with the energized buss during such an event.
There's also a white 4-1/8" round flush metallic box blank used non-compliantly as a reducing washer. |
Marc, it is the following for a control system.
http://www.aartech.ca/product_info.p...d/68/6299.html Leviton X10 Signal Bridge [Leviton 6299] |
Thanks....Always the best information on this message board.
![]() Leviton Manufacturing Co Inc Authorized Distributor 6299 Signal Coupler/Bridge Bridge helps assure sufficient signal strength throughout 3-wire systems. The Signal Bridge coupler the command signal onto the 120V legs of the power system to ensure sufficient command signal strength throughout the command network. Use of the 6299 is recommended for all installations. The wiring diagram shows the proper method for coupling a typical residential 120/240V system. When used in the same DHC network as a 6201 system Amplifier, the 6299 Signal Bridge should NOT be in the same panel or within 10 feet of the 6201. Dimension of 6299 is 2.693" x 4.125" x 1.387". LE-6299Signal Bridge List 50.00 each $39.95 each Enter Qty each
As soon as I saw the pic I knew what it was. As I scrolled down I see other did as well. It IS a signal bridge.
That one IS designed to go in a wall box. I have seen them that they recommend simply laying it in the panel. |
Signal bridge? Cool... learned something. Don't do X-10, and seldom run into it. The X-10 geeks are generally DIY types, so they don't oft call for an electrician.
The comment on the non-compliant reducing washer stands. |
I'm troubled by someone who gives such voluminous and verbose electrical advice that wouldn't recognize an X-10 Signal Bridge when presented with one. That's pretty basic knowledge and anyone with much experience would surely recognize one.
I've seen darned little X-10 anything, except for some of the stuff RadioShack used to sell in the 80's; and then, only at the store. Real electricians don't use X-10. We use wires! |
Appropriate... InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
