kpierce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I haven't seen one before.
A type of mechanical connector. It has two lugs, set inside, so you can splice two larger guage wires together.
Jeff Last edited by jwicklander; 11/10/08 at 4:00 PM.. |
Electricians call those a "Polaris Bug" or "NSI Bug".
Thanks Marc.
OK, but ...why are they splicing a large gauge to a small?
I would check the rating of the breaker on that and the circuit at the back of the pic, same situation. John Kogel www.allsafehome.ca |
1) To repurpose an old #6 50 amp feed to an electric range for use as a 20 amp feed to a gas range. A smaller wire needs spliced on to attach to the terminal of a 20 amp breaker 2) To run very large conductors to parking lot lights, to overcome voltage drop, but connect them to a 20 amp breaker. |
Neither have I, learn something everyday here.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
This is the reason that I dumped OAHI and have stuck with NACHI!
