Old 6/27/09, 4:20 PM
David K. Lee David K. Lee is offline
Default a
Had a double pole 30 amp breaker today wired with 10/2 wire and on side of the breader open. It was for the a/c unit. Not sure what the other letters stand for on the panel. Is this acceptable. I believe it is the wrong breaker for the application.
Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America)
Old 6/27/09, 4:54 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: a
Typical AC units require 240 volts and a 2 pole breaker.
Perhaps the breaker purpose has been changed and not relabeled as to its new usage. Did you verify that this was for the AC? What did the nameplate call for?
Old 6/27/09, 5:21 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: a
probably "electronic air cleaner" It should be a single pole breaker. My mom always said "if something is worth doing, it's worth doing right."
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 6/29/09, 12:09 PM
Default Re: a
Looks like they have installed an Ultra-Violet light to combat mold in the air handler. Did you see a window on the air handler or furnace with a blue light showing through?
Abraham Lincoln
Old 6/29/09, 12:40 PM
Michael Larson's Avatar
Default Re: a
I've seen a few of these lately on high end homes.
http://www.naturalsolutions1.com/ventductuv1.htm
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 6/29/09, 12:58 PM
Default Re: a
Lots of them here. I haven't personally seen a difference in the amount of mold in the homes with them, but maybe that's just me. Snake oil works too...
Abraham Lincoln
