| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
This round flourecent light when the switch is turned on will not light.it will only light when you put your hands up to it within 2 inches (not touchinig).The timing makes no difference 1 second 10 seconons 1 minute or 1 hour. Any thoughts.
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
Sounds like the fixture is not properly grounded.
My guess is a faulty starter. Or, a lack of a ground.
Robert Newland Tyrone, GA 30290 NACHI05101290 http://www.CertifiedHI.com http://www.HomeInspectorTyroneGa.com Last edited by rnewland; 10/4/09 at 11:22 PM.. |
Jeff Rema is a non-member guest and is in no way affiliated with InterNACHI or its members.
Flourescents are notorious for acting weird due to proper grounding. Your ballast or starter depending on the age and type of fixture may also be the culprit.
