Old 7/14/10, 8:47 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default AC disconnect/Distribution panel wiring
Do exterior AC disconnects need to be wired like a distribution panel with ground & neutral separation/isolation?
Thanks in advance.
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/14/10, 9:09 AM
Bruce A. King's Avatar
Default Re: AC disconnect/Distribution panel wiring
Technically, yes, but most of these do not use any 120V neutrals so it would not be a big deal. You would just have a doubled up conductor (white and bare copper) being used as a 240V equipment ground.
Did they actually run a three conductor with an additonal ground to the disconnect?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 7/14/10, 9:12 AM
No. Just got me wondering. Thanks for the help.
Old 7/14/10, 10:13 AM
David A. Andersen's Avatar
If it's a 110vac disconnect for a furnace, yes if not, no.
BPI# 5015804
Old 7/14/10, 3:52 PM
bstenger bstenger is offline
no seperation is necessary, why, the wiring is a branch circuit, not a feeder. The NEC defines a feeder as a circuit that is installed to supply power for a multipile pieces of equipment, i.e a sub-panel, because u would take from that s-p other branch circuits.
A branch circuit is a cir that supplies power to something that actually consumes power, like an A/C, light bulbs, ref. toaster, microw.
If the electrician ran 3cond. w/ ground, he is a step ahead of the rest
Praise God for good friends
Bill
State Elec. Inspector
Bill Stenger
master electrician/licensed elec inspector (oh,KY)
certi. bldg inspector (I.C.C.)
Old 7/14/10, 3:53 PM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
There could be a problem if this circuit is fed from a subpanel. By grounding the neutral at the disconnect you've created a parallel path for the neutral current to flow on the EGC feeding the subpanel.
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Panel wiring question dmacy Electrical Inspections 12 2/2/09 8:38 PM
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
