I called these disconnects as missing interior cover plates. Electrician disagrees. Looking for help on this one. Exterior covers are present. Thanks.
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Ask the electrician if his kids or grandkids were playing in the yard, and they opened the cover, would he be comfortable with them sticking their hands in there and grabbing the wires.
There is no "interior" cover in an electrical panel, but the dead front is secured by screws. In this case there is an exterior cover, but it is not secured. Whether it is "required" or not, seems to me to be a moot point. It isn't safe. He can fix it, or not. That's between he and your client. I would tell him, and the client it's not safe, and then let them work out the rest. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Mark,
Thanks for the response, my thoughts exactly. Attached image of closed exterior cover, no lock. ![]()
Are you going to re-manufacture that thing, or make an inside cover for it?
![]() That pnl is designed NOT to have any exposed wiring connections. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
David is correct. There are no exposed, live components when the cover is open. These do not require an interior (dead front) cover.
Well, I made an error, thanks for the information. I will say that most disconnects do have a "dead front". I guess the manufacturer saved a buck!
I don't like them, but it's by design. Here's another thread on the subject.
http://www.nachi.org/forum/f19/insid...equired-11776/ “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Learn something new EVERY day...
What is the purpose of the cover? What is the purpose of this design? Oh ****, that's right. Must keep the home inspector happy! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Rightfully or wrongly I thought that electric wire exposed to potiental danger to cutting or knicking (weed wacker) are required to be protected ie in conduit Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
David, if you're referring to me, I simply said I don't like them. Meaning I would choose not to buy one when I could buy one with a full dead front cover instead. I would guess that this type is a few cents cheaper. There is nothing wrong with it from a code or protection standpoint, however.
| Ballast Disconnects | jkaylor | Commercial Inspections | 10 | 12/6/09 9:23 PM |
| 2 Service Disconnects | tlarsen | Electrical Inspections | 11 | 8/21/09 8:41 AM |
| Two disconnects | gheller | Electrical Inspections | 6 | 8/12/09 8:50 PM |
| Ballasted fixture disconnects required | jtedesco1 | Electrical Inspections | 15 | 3/27/09 8:57 AM |
| Two disconnects | bsmith | Electrical Inspections | 4 | 4/20/06 10:19 PM |
