Rick Maday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I saw this in a local newspaper here. Here is a link to the entire article.
http://www.dailyherald.com/column/?id=106357 Here is an excerpt. The bold is mine, is that accurate? "In determining when double-tapping is or is not acceptable for a particular circuit breaker, a simple rule of thumb is to check the design of the connecting hardware at the breaker. If the hardware is specifically shaped to accommodate two separate wires, as with Square D type QO breakers, then the connection is acceptable and should not be cited as double-tapping in a home inspection report. But if the connecting hardware is a simple screw or lug, it is reasonable to assume that the manufacturer of the breaker intended there to be one wire only at the connection. In that case, double-tapping would be the proper disclosure for a home inspector. The only way to connect two circuits to a single breaker in that instance would be by indirect means. The accepted method would be to connect a short wire (known as a "pigtail") to the breaker and to join the other end of that wire to the two circuit wires with an appropriate connector, such as a wire nut. " |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
sounds accurate
Yes...
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Thanks
Yep.
Pigtails are acceptable, but there is also too much of a good thing. I have seen panels with 10 or 12 pigtails. In that case, it is close to the time that a new and larger panel be installed. Some local municipalities (like Chicago and some surrounding towns) to not, by local code, allow double taps even if the breaker is designed for it. Chicago also does not allow mini breakers (two breakers on one lug) even if the manufacturer does. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
That was my concern when I read that, I was imagining a box full of pigtails! Is there a reference for how many pigtails are allowed? Quote:
| How accurate is your perception? | mlarson | Miscellaneous Discussion for Inspectors | 0 | 7/17/07 12:11 PM |
| Type "missouri hb 978" into a Google search and see what comes up. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 49 | 3/30/07 7:50 AM |
| How Long Does It Really Take To Sell Your Home? | jburkeson1 | General Inspection Discussion | 1 | 2/13/07 7:02 AM |
| Are these message board numbers accurate? | jeubank | General Inspection Discussion | 16 | 10/26/06 3:32 AM |
