on an older two wire system can a single bare copper ground wire be added and run to the crawlspace and hooked to a looped ground wire connected to the ground bar in the panel ?
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sounds wrong. Running a ground wire is one thing... but bare copper?
For what purpose? |
he wants to update the old two wire with grounded outlets and not totaly rewire the whole house or open all the walls.
Isthis for all receptacles or just ones in the crawlspace?
all the rec on the main floor, bring the wire down and tie to one ground wire in the crawl and run it to the panel
Sounds like if done and all connections are secure, it would be an effective ground. If I were to find this during an inspection, I would report it as "amateurish wiring added that should be further evaluated by a licensed specialist."
(C) Nongrounding Receptacle Replacement or Branch Circuit Extensions. The equipment grounding conductor of a grounding-type receptacle or a branch-circuit extension shall be permitted to be connected to any of the following: (1) Any accessible point on the grounding electrode system as described in 250.50 (2) Any accessible point on the grounding electrode conductor (3) The equipment grounding terminal bar within the enclosure where the branch circuit for the receptacle or branch circuit originates (4) For grounded systems, the grounded service conductor within the service equipment enclosure (5) For ungrounded systems, the grounding terminal bar within the service equipment enclosure |
Here's what the 2008 NEC says:
Why not just drive a ground rod and run a proper wire to the panel?
What would the ground rod actually do?
Hmmm - guess I didn't understand the question exactly...
Frank, ground rods are to ground the system against high voltage events like lightning strikes or surges. They have nothing to do with an equipment grounding conductor that runs to the third prong on a receptacle.
As I said, I misunderstood the original question, so my comment was not applicable.
would changing to GFCI outlets be an acceptable solution. Its my understanding they don't provide a ground but do provide personal protection and would allow for modern appliancec to be used, but not grounded
Yes, that would be an acceptable solution as outlined by the NEC. As you've stated it would provide personal protection, but a GFCI device cannot be used as a substitute for grounding.
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 5 | 3/25/07 10:41 PM |
