Is it OK to install a 2nd receptacle below the main panel? If so does it need to be GFCI protected. House is 10 years old. Looks like it was added on for a basement computer.
If it is an unfinished basement it would still need to be GFCI protected.
Paul W. Abernathy |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
A single receptacle or a duplex receptacle for two appliances located within dedicated space for each appliance that, in normal use, is not easily moved from one place to another and that is cord-and-plug connected or A receptacle supplying only a permanently installed fire alarm or burglar alarm system |
Easier Mike to keep the answers to the question the HI posts.....anything other than their question tends to confuse.
So as it pertains to this question (ie: picture ) if the location of this panel is unfinished it should be on GFCI. Paul W. Abernathy |
| Addition | dlee2 | Structural Inspections | 1 | 8/9/07 6:59 PM |
| Bedroom receptacle | dnasser | Electrical Inspections | 9 | 4/16/07 10:33 AM |
| Online Code Check- Reference | pabernathy | Electrical Inspections | 31 | 11/9/06 3:39 PM |
| Wiring a Receptacle | jallingham | Electrical Inspections | 9 | 8/6/06 4:34 PM |
