The home i inspected today had three AFCI's in the panel, I noticed when I tripped them that they were quite warm. I used my infrared thermo to see how warm they were, the top one read 108, the middle 112, and the bottom 106. Should they be this warm when the home is vacant?
Mark Simmons JAM Home Inspections Maricopa Az 85139 NACHI 03121906 |
| Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America) |
Some brands run warmer than others even with no load, usually the top one is the warmest if they are stacked vertically. If they test ok you can't really say those temps are unusual unless you have some data.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
They are fine.
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Thanks again. Mark Simmons JAM Home Inspections Maricopa Az 85139 NACHI 03121906 |
AFCI's can reach temps 15-20 degrees higher than a normal breaker. In Arizona since the ambient temps are higher you might get higher readings than lets say the ambient in new york for example. however, while the range may vary the results will be generally the same.
Whenever a breaker (or other electrical device) contains active circuitry, some heat rejection should be expected. In this case, the electronics that are monitoring the voltage and current waveforms require power to operate. Since this power comes from the 120 v supply of the breaker itself, it has to be stepped down. That activity, as well as those of other circuit components, reject heat much like the heat generated by a desktop computer. So yes, they will operate hotter than a more passive breaker (or even a gfci) but are designed to operate safely under relatively high ambient conditions.
Do you guys ever have trouble resetting them? I've had some that need what seems like a little "cool down time" after doing the test button...they always eventually reset but some just take a few tries.
Harry "Bud" McClard Serving All of New Hampshire |
Never had a problem so far - but haven't seen a lot of them around here yet (or haven't inspected enough newer homes)
One brand, forget right now, has a rocker type test switch that gets stuck to one side, you might not notice it and after pushing on the lever a few times trying to reset, it will pop back in place and presto it works again!
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| AFCI Controversy | rcooke | Electrical Inspections | 11 | 9/10/07 3:14 PM |
| AFCI's Explained by Mike Holt & Eaton Engineer | pabernathy | Electrical Inspections | 19 | 2/15/07 1:05 PM |
