New the business, I took the online course, and it said that
in the bedrooms as 2002, Afci receptacles are now code. As there anybody out there who could put a picure of one online. David Nasser Pyramid-Home-Inspections |
Here you go. Always good for a search on google. Try the image section.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 3/22/09 at 2:29 AM.. |
In 2008 all single pole breakers will be required to be AFCI if the coordinating committee doesn't change something from the ROP. It is amazing that they are mandating universal installation of a technology that is still in development but that is just my opinion.
Personally I think the NFPA/government is out of control. Maybe it's time to throw some AFCIs in the harbor. |
Thanks
Thanks everbody, those pictures did the trick..
On this issue I agree......I do not agree with the idea of AFCI's on all 1-pole breakers......however since I am in VA...lol.......and we are usually 3 years behind each code change.....it will be 2011 before we have any visions of that if it goes through. But you are right......to me a bit over the top at this point. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Joe,
I think greg and I are simply voicing our displeasure of AFCI's on all 1-pole circuits...not their function... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Oh snap........your post was for the original poster...Sorry Brother......just got my panties in a BUNCH over the AFCI on all 1 pole thing...thehehe
I wonder if anyone has done a heat load calc with a couple dozen AFCIs in the same panel in an uncooled garaage in the summertime.
If you don't agree with any of the proposals you can send in a Public Comment and ask for a Reject.
Be sure to give your reasons why. http://forums.nfpa.org:8081/pcsubmit/pctop.html Here's the Proposal Greg mentions here: 210.12 Arc-Fault Circuit-Interrupter Protection. (A) Definition: Arc-Fault Circuit Interrupter (AFCI). An arc-fault circuit interrupter is a device intended to provide protection from the effects of arc faults by recognizing characteristics unique to arcing and by functioning to deenergize the circuit when an arc fault is detected. [ROP 2–119] (B) Dwelling Units. All 120-volt, single phase, 15- and 20-ampere branch circuits installed in dwelling units shall be protected by a listed arc-fault circuit interrupter, combination type installed to provide protection of the branch circuit. [ROP 2–105, 2–142, 2–111] FPN No. 1: For information on types of arc-fault circuit interrupters, see UL 1699-1999, Standard for Arc-Fault Circuit Interrupters. FPN No. 2: See 11.6.3(5) of NFPA 72®-2007, National Fire Alarm Code® for information related to secondary power supply requirements for smoke alarms installed in dwelling units. [ROP 2–118a] FPN No. 3: See 760.41 and 760.121 for power supply requirements for fire alarm systems. [ROP 2–143] Exception: The location of the arc-fault circuit interrupter shall be permitted to be at other than the origination of the branch circuit where the arc-fault circuit interrupter is installed within 1.8 m (6 ft) of the branch circuit overcurrent device as measured along the branch circuit conductors. [ROP 2–147, 2–137] Last edited by jtedesco1; 7/27/06 at 10:17 AM.. |
smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are AFCIs available in slim (mini) breakers? If not, the proposal would limit the number of circuits that could be added to the panel.
Steve,
Why is that...? The maximum amount of OCPD's in a panel is 42.....last I checked the AFCI's take up the same space a single pole breaker so the proposal is just saying the current single pole 15A and 20A breakers used now will have to be AFCI breakers........so really does not change the maximum number of OCPD ( breakers ) allowed in a panel... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| AFCI Controversy | rcooke | Electrical Inspections | 11 | 9/10/07 3:14 PM |
| AFCI's Explained by Mike Holt & Eaton Engineer | pabernathy | Electrical Inspections | 19 | 2/15/07 1:05 PM |
